Re: Windows 7 PC suddenly powers off
Posted:
Fri Sep 25, 2020 4:45 pm
by James Perrett
Marbury wrote:Just about to go for it but realised it's a 450 w, where mine old one was 430 w so not sure it would be too powerful
For a PC power supply, more power is good - too little power is bad.
Posted:
Fri Sep 25, 2020 5:31 pm
by Marbury
Ok, I got inside the pc and managed to disconnect the PSU (which was an ordeal in itself as so many wires) and tried to run this test with my multi meter. Unfortunately the fan didn't stay on long enough to run the test. It just cut off almost imediatley.
is it a safe bet that the fan is the issue and needs replacing or the whole PSU ?
Posted:
Fri Sep 25, 2020 5:39 pm
by James Perrett
Marbury wrote:is it a safe bet that the fan is the issue and needs replacing or the whole PSU ?
It is much more likely to be a PSU problem so it would be sensible to buy a replacement PSU.
Posted:
Fri Sep 25, 2020 6:10 pm
by ef37a
I know this sounds a bit 'untechnical' but have you tried giving it a slap?
The computer in my living room has had a fault for years whereby sometimes it does not start up and a bumping the case gets it going. It has been very good for a long time but just a week ago the DVD drive died. Got one from the PC repair shop down the frog for a score and it fixed that but, today, at 7am it started up but cut out 5 mins later. Pushed the button, running again, barely got Radio 3 on and, dead again. Gave it a slap and it has been running ever since.
Now, a year or so ago I decided to fix this and had it on the table running and pushed and pulled EVERYTHING. Could not make it go off. Put it all back and it was fine for a month then "Bing! Off again.
Thing is you see, if a "technically applied acceleration"is applied and either starts it up or causes it to fail you know you are looking for a bad connection or dry solder joint. FINDING same is whole other barrel of fish!
Posted:
Fri Sep 25, 2020 7:01 pm
by blinddrew
"Percussive maintenance" they used to call it...
Posted:
Fri Sep 25, 2020 8:15 pm
by merlyn
Marbury wrote: Unfortunately the fan didn't stay on long enough to run the test. It just cut off almost imediatley.
It sounds like you have the power supply plugged into the mains with nothing connected. When you plug it in like this the fan can briefly spin up. The power supply isn't on. To switch it on you need to short the 'on' pin to ground. You can look up a pinout for your exact connector to find out which one is the 'on' pin.
Posted:
Sat Sep 26, 2020 1:32 pm
by Marbury
Yes I did that by following a Youtube video with a bent paperclip, but it still didn't work. I reconnected the PSU back to the PC ad it won't power up at all now, not even the fan. Not sure what to do now as I still don't know for sure what the problem is.
