Crackling and slowing down of project in Reaper
Re: Crackling and slowing down of project in Reaper
Postby Marbury » Wed Sep 23, 2020 3:21 pm
The sample rate displays 48khz 16 bit WAV. My playback and render settings are both extreme HQ.
Marbury
Postby James Perrett » Wed Sep 23, 2020 3:30 pm
The important thing is whether your files match that sample rate. Are there any blue circles with i in them above the audio? If you select a piece of audio, hit F2 and then click on the Properties... button what does it say?
Also - are you using and processing intensive reverbs?
Postby Marbury » Wed Sep 23, 2020 5:17 pm
James Perrett wrote:The important thing is whether your files match that sample rate. Are there any blue circles with i in them above the audio? If you select a piece of audio, hit F2 and then click on the Properties... button what does it say?
It says Bits/sample: 32 (float)
Marbury
Postby James Perrett » Wed Sep 23, 2020 6:01 pm
What else does it say?
Postby Romy Schmidt » Thu Sep 24, 2020 7:41 am
Marbury wrote:For the life of me I don't know why a new pc with 16 GB ram on an i5 9600 3.70ghz is struggling with a modest project when I try to patch in the Ozone 7 into the main stereo output track.
Render the entire project without Ozone 7. Load the wave in a new project and then apply Ozone 7. That way you can test if Ozone 7 is the problem.
Romy Schmidt
This is not a signature.
Postby Mike Stranks » Thu Sep 24, 2020 8:24 am
Good plan! :thumbup:
When I'm working on music I'll usually treat the mixing and the mastering as two discrete activities. I regard Ozone as a mastering tool.
