Partitioning SATA drive
Postby Mus » Thu Oct 01, 2020 11:57 pm
Hello Peeps,
I have a Scan 17" 3XS laptop with a 256GB SSD plus 2 1TB SATA drives for AV and Samples/Data respectively.
I also have a lighter 15" laptop with a 256GB SSD plus 1 2TB SATA. Is it OK to partition the latter drive to replicate the 17" setup? It makes transferring projects and iTunes etc. easier if all the sample and media links refer to the same location.
Thanks!
M
Mus
Murray Webster London Songwriters - Collaboration Songshare Retreats Community
Re: Partitioning SATA drive
Postby Eddy Deegan » Fri Oct 02, 2020 12:09 am
If you mean partitioning the SSD drive on the laptop to accomodate the data on the 3XS laptop then that should be fine.
Personally I'd probably not bother with the partitioning and just create two folders on the non-3XS laptop, one for each drive on the 3XS but that wouldn't replicate the drive letters of course (do they matter that much for backups?)
Some of my works
Postby Agharta » Fri Oct 02, 2020 12:21 am
It's fine to do that if it helps your management of data.
Agharta
Postby Mus » Fri Oct 02, 2020 12:39 pm
Thanks guys, yes it's partitioning the 2 TB SATA into two 1 TBs.
I assume a modern drive can cope with the sample loading/playing and audio streaming with no probs.
The CPUs and 16GB RAM all cope fine too.
Cheers
M
Mus
Postby Agharta » Fri Oct 02, 2020 2:05 pm
Mus wrote:I assume a modern drive can cope with the sample loading/playing and audio streaming with no probs.
It depends entirely on your workload.
If by SATA you mean SATA SSD as opposed to SATA HDD then that will help a lot.
Agharta
Postby Mus » Fri Oct 02, 2020 2:13 pm
Ah...good point...it's a Samsung SATA HDD...
Mus
Postby wireman » Sat Oct 03, 2020 9:40 am
There are ways to map drive letters to folders but I'm not sure if they have downsides.
wireman
Re: Partitioning SATA HDD drive
Postby Mus » Sat Oct 03, 2020 10:44 am
wireman wrote:There are ways to map drive letters to folders but I'm not sure if they have downsides.
Yes indeed, I was successfully mapping my OneDrive as an entirely separate virtual E: Drive on bootup. Subfolders here can then be redirected to other folders.
However, Native Instruments Komplete for example does not allow for virtual drives.
I can feel a new strategy evolving if partitioning an HDD is potentially unwise?
BTW the 2 TB drive crashed so until Scan replace it I have an opportunity to rethink.
M
Mus
Re: Partitioning HDD SATA drive
Postby Mus » Tue Oct 06, 2020 10:59 am
Any more thoughts on the partitioning, folks?
In terms of workload I probably load 16 or so audio tracks from one disk and usually only bass, organ and piano samples from the NI folder, EZDrummer on the other plus the usual NI, Sonar, Izotope plugins.
Doesn't sound too much for a 16GB RAM, 2.2GHz i7?
Cheers
M
Mus
