I wanted to amend my last post but SOS forum seems not to allow edits after some time which is a bit strange.
Anyway, I have managed to format my new drive which now shows in "This PC" The problem now is AOMEI cloning software does not see it. I am stuck.
New hard drive not seen device manager, possibly damaged ?
• Page 2 of 2 • 1, 2
- Marbury
- Frequent Poster
Re: New hard drive not seen device manager, possibly damaged ?
I am unfamiliar with AOMEI, possibly it doesn't recognise the file system you formatted the disk with, although you probably formatted the disk as NFTS, which it should recognise.
For disk cloning I use the free version of Macrium reflect and never had any issues with it.
https://www.macrium.com/reflectfree
For backup I use SyncBack, which has an excellent free version
https://www.2brightsparks.com/syncback/ ... k-hub.html
If you stick to those you should be OK, although I am not saying that there aren't equally good products out there, but I don't use them.
- Trevor Johnson
- Regular
Trevor Johnson wrote:I am unfamiliar with AOMEI, possibly it doesn't recognise the file system you formatted the disk with, although you probably formatted the disk as NFTS, which it should recognise.
Thanks but I was looking for something free that I am not tied to paying for once the trial is over.
- Marbury
- Frequent Poster
Marbury wrote:Trevor Johnson wrote:I am unfamiliar with AOMEI, possibly it doesn't recognise the file system you formatted the disk with, although you probably formatted the disk as NFTS, which it should recognise.
Sorry to be so direct but might I suggest you read the content of the products' website fully. Both Macrium and SyncBack offer totally free to use as well as 'free to download - trial' versions of their software. And those free versions are very good. I have used both for longer than I care to remember. Both products are regularly updated by the respective companies. All you need to is look at all the web-pages for the options systematically and you'll drop on the respective links for the totally free versions of their products.
- OneWorld
- Frequent Poster (Level2)
I was about to come back to you and say that I had missed the free link. There is just so much clag to read through before you find what you want.
Now I have installed it and attempted to clone, I am getting another brick wall. I am cloning the Windows 10 C drive (500GB) onto a WD 1TB formatted drive but I am getting the error "the target disk has an incompatible sector size for this operation, please choose a different disk" I can't get past this.
- Marbury
- Frequent Poster
