Is there such a thing as a switched USB cable?
Postby blinddrew » Fri Nov 06, 2020 4:42 pm
I can find a few usb power cables with switches in, but not any that handle data as well.
Does anyone know of one?
Cheers
Drew
Re: Is there such a thing as a switched USB cable?
Postby BJG145 » Fri Nov 06, 2020 5:21 pm
I thought I'd seen everything. A what?
*edit*
Oh OK, here's an extension that seems to do it...
https://www.amazon.co.uk/RIITOP-Extensi ... NrPXRydWU=
Postby Eddy Deegan » Fri Nov 06, 2020 5:38 pm
Is that for the recording-in-progress light? :)
Some of my works
Postby blinddrew » Fri Nov 06, 2020 5:41 pm
ah, yes that seems to interrupt the data as well as the power side. Thank you.
Postby Martin Walker » Fri Nov 06, 2020 7:51 pm
Eddy Deegan wrote:Is that for the recording-in-progress light? :)
Yes, that's what I was wondering too Eddy ;)
Postby desmond » Fri Nov 06, 2020 8:02 pm
Let me know if it works - I could do with one.
(I hate these USB devices that have no power switch. I don't want to have to disconnect and reconnect all the time just to turn a master keyboard on/off - annoying.)
Postby BJG145 » Fri Nov 06, 2020 8:27 pm
...plenty of hubs with individual switches of course, which is what I use...
https://www.amazon.co.uk/Sabrent-4-Port ... 5910&psc=1
Postby blinddrew » Fri Nov 06, 2020 8:30 pm
Sadly not, I've worked out that the BSODs on my computer are caused by my interface and i'm looking for an easier way of turning it on and off.
Postby desmond » Fri Nov 06, 2020 8:44 pm
BJG145 wrote:...plenty of hubs with individual switches of course, which is what I use...
Hmm, that’s a good idea...
Postby blinddrew » Fri Nov 06, 2020 9:18 pm
Do they give a complete circuit cut? Or just power?
Postby BJG145 » Fri Nov 06, 2020 9:37 pm
blinddrew wrote:Do they give a complete circuit cut? Or just power?
I'm not sure...I've got this one at work but I'm not back until Tuesday. How would you test that? Don't all USB devices need power?
Postby blinddrew » Fri Nov 06, 2020 9:58 pm
My interface has a separate power supply, so i need a switch that disconnects the unit completely.
Or i just go behind the desk and unplug it.
Postby Hugh Robjohns » Fri Nov 06, 2020 10:01 pm
Rather disturbing that an interface causes BSODs...
Postby desmond » Fri Nov 06, 2020 10:11 pm
BJG145 wrote:Don't all USB devices need power?
I have a Kensington 7-port hub connected to my Mac.
USB devices can draw power in a number of ways:
- Devices can draw power from the USB host (the computer)
- Devices can draw power from the USB hub (my USB hub can be optionally powered by it's own adaptor - mine is)
- Devices devices can have their own power supply and draw no power from USB at all
I have devices that draw power from the hub (including my master keyboard), and also devices that draw power from their own power supplies (eg hard drives).
It would be nice to have a switch on at least some ports to do the same job as disconnecting the USB cable completely (which I assume is the point of these switches).
Postby blinddrew » Fri Nov 06, 2020 10:19 pm
Hugh Robjohns wrote:Rather disturbing that an interface causes BSODs...
Indeed. Well, it's probably the drivers rather than the interface i guess, but I've done quite a bit of testing and it does appear to be the culprit.
