Is there such a thing as a switched USB cable?
Re: Is there such a thing as a switched USB cable?
Postby N i g e l » Sat Nov 07, 2020 1:43 am
There are probably USB port control options in the BIOS eg to leave the USB on/off when the computer is OFF. Have you investigated those ?
Postby Eddy Deegan » Sat Nov 07, 2020 2:26 am
I've been using one of these for a year or more and find it perfectly satisfactory. One of the devices hanging off it is the Arturia Keylab Mk II and it serves as the power switch for same. https://smile.amazon.co.uk/gp/product/B081NK6LH6/
Some of my works
Postby ef37a » Sat Nov 07, 2020 2:30 am
I have a wee box that allows two USB devices to alternately use one computer IUSB port.
If I can find it you are welcome to it.
Postby blinddrew » Sat Nov 07, 2020 4:01 pm
N i g e l wrote:There are probably USB port control options in the BIOS eg to leave the USB on/off when the computer is OFF. Have you investigated those ?
I don't think this is going to help, though I may well be misunderstanding - BIOS is out of my league computer-wise. I need the data side of the USB to be off throughout the boot-up cycle of the computer, not just when the machine is off.
@Eddy, something like that (or the smaller one linked earlier) would do the job if they cut the whole connection not just power. I might just have to shell out an entire £6.99 and stick a multi-meter across the connections.
But, well, £6.99 is practically a year's royalty income*... ;)
@Dave, ooh, hadn't thought of a 'switcher'. Will have a quick google.
Or I could just stop being lazy and bend down and plug and unplug it each time.
#firstworldproblems
* I'm lying of course, it's waaaay more than that.
Postby Kwackman » Sat Nov 07, 2020 9:00 pm
Kwackman
Postby blinddrew » Sat Nov 07, 2020 10:47 pm
Possibly, need to check the reviews and see if definitely cuts data as well as power. It seems a surprising number don't.
Postby James Perrett » Sat Nov 07, 2020 10:51 pm
Why not just cut the power to the interface until your machine has booted? It should be easy enough to wire a switch into the power cable. The standard procedure with my Focusrite interface is to switch it on only once the computer has finished booting - fortunately mine has a front panel power switch.
Postby blinddrew » Sat Nov 07, 2020 11:04 pm
Mine doesn't have a power switch so i'd have to cut into the power supply cable and do it like that. Which wouldn't be tricky i guess.
Postby James Perrett » Sat Nov 07, 2020 11:11 pm
You might need something like this
https://www.lindy.co.uk/cables-adapters ... -5mm-p9463
(That's just an example - I don't know what connector size the interface uses).
Postby N i g e l » Sat Nov 07, 2020 11:13 pm
I cant help feeling theres a windows 10 services setting to cover peripheral start up boot time.
My Laser printer is very old, used to start up ok [XP/W7 & HD] but now I need to turn it on after booting the PC.
Is this because the combination of W10 + SSD gives a start up so fast that it outpaces the printers boot time scale ????
Postby blinddrew » Sat Nov 07, 2020 11:14 pm
Ah yes, that would do the job. Will get the ruler out. :thumbup:
Postby Martin Walker » Sun Nov 08, 2020 12:38 am
blinddrew wrote:Sadly not, I've worked out that the BSODs on my computer are caused by my interface and i'm looking for an easier way of turning it on and off.
Is this the same interface that was causing audio distortion problems in Zoom conferences, or the other one (that worked well with Zoom)?
Postby blinddrew » Sun Nov 08, 2020 12:33 pm
The same one. Though interestingly that doesn't seem to be happening any more.
Postby blinddrew » Sun Nov 08, 2020 4:17 pm
James and Music Wolf have hit upon the solution between them.
Put all the peripherals on a separate power strip and switch them on when everything else has booted up.
Easy.
Now why didn't I think of that? :headbang:
Postby desmond » Wed Nov 11, 2020 12:53 pm
I've ordered another USB hub to replace (or complement) my existing Kensington dalek.
I went for this one, which is a 7-port hub with port switches and a charging port:
https://www.amazon.co.uk/gp/product/B07 ... UTF8&psc=1
We'll see how it goes...
