Page 1 of 1
Alternative to QuickTime Pro in Win 10
Posted:
Tue Nov 17, 2020 5:42 pm
by emptybe
Hi All. I'm still ironing our the kinks after upgrading to Windows 10. Among the many 'surprises' :madas: are that QuickTime Pro doesn't work properly any more. I write music to picture for a living and found a workflow of taking the QT file I'm send by editors, then using QT pro to add an mp3 of the mixed audio to that file and just 'save as' a QT file.
But in Win 10 it does...nothing. Doesn't save or keep the audio files. Has anybody found a workaround? Or is there some other alternative app that I can just add the audio to an existing.mov or MP4 file and save as a QT file rather than having to re-render?
Re: Alternative to QuickTime Pro in Win 10
Posted:
Tue Nov 17, 2020 6:39 pm
by manwilde
Not familiar with QT, and I'm on Win7, but Reaper's Batch file/Item converter might work for you...
Posted:
Tue Nov 17, 2020 6:55 pm
by James Perrett
manwilde wrote:Not familiar with QT, and I'm on Win7, but Reaper's Batch file/Item converter might work for you...
Yes, Reaper would do it but I think you would need to re-render the video (unless they've changed things since I last checked).
Posted:
Tue Nov 17, 2020 7:22 pm
by emptybe
Thanks for the replies. I already use Vegas to mix the audio to video which I can then render from but it's slow and usually results in bigger but worse resolution video files than the one's I receive as they're coming from 'proper' edit suits. That's why just sticking my audio onto the original video file works so well...
Posted:
Tue Nov 17, 2020 11:38 pm
by blinddrew
Is it a case of W10 not having the relevant codec by default and this being something you need to download?
Posted:
Wed Nov 18, 2020 12:19 am
by resistorman
QT never was well supported on Windows and they officially killed it four years ago:
https://www.extremetech.com/computing/2 ... hard-placeYou’ll want a muxer, maybe this will help?
https://www.videohelp.com/software/MP4MuxerLikely Mov files are just mp4, you can just change the .mov to .mp4
Posted:
Wed Nov 18, 2020 7:48 pm
by BillB
resistorman wrote:Likely Mov files are just mp4, you can just change the .mov to .mp4
Googling turns up:
What are the differences between MOV and MP4?The main difference between these two container formats is that MOV is mostly for use within Mac environments. MOV is a proprietary Apple file format for QuickTime, while MP4 is an international standard. On a Mac, MOV and MP4 are basically interchangeable, and either type of file will play easily. But on other types of devices, video MOV files need to be converted to MP4s or another file format.
MP4 are typically more compressed and smaller in size, while MOV files are often higher in quality and larger in size. MOV files are better for video editing on a Mac, since they're specifically designed for QuickTime.So - similar but not the same.
Posted:
Fri Nov 20, 2020 11:31 am
by emptybe
Thanks for this. it sounds roughly like what I need but that one didn't work - it didn't recognise any .mov files I use.
Posted:
Fri Nov 20, 2020 4:04 pm
by resistorman
Make a copy of your .mov file and change it to .mp4 and see what happens. Not saying that it will work all the time, but it’s saved me from a lossy conversion many times.
