I update the app as well as the X32 firmware whenever there's an update available.
Today, after a few days normal use with the latest software, Windows reports "X32-Edit.exe has stopped working. A problem caused the program to stop working correctly. Windows will close the program.
I switched over to another computer and got the same message. I re-download the software and firmware, and got the same problem, so no corrupt files.
I ran the software as an administrator, I also backtracked on recent Windows updates, I cleared the computer of any open apps, I ran a clean up program - all to no avail.
Then I downloaded the M32-Edit (which I'd read works just the same) and Bingo! it worked. For half an hour at least, - then the dreaded message popped up again. HOWEVER this time I had the option to close the message, not the app. Lo and Behold, - the app is working fine. I haven't closed and re-opened it though in case it doesn't load at all giving the dreaded message again.
I also ran the MAC version of the app and it worked fine (though obviously with no touch screen)
Has anyone here experienced this, and if so how did you resolve it?
