HP Ravillion x360 for Windows music production?
Postby 4TrackMadman » Wed Dec 02, 2020 9:32 pm
Got a great deal on this PC,
wondering if it will be allright for audio production.
Running Studio One ver 4 now and my Windows 7 machine took a nosedive recently.
Also running EZDrummer, several instances of guitar audio (Amplitube 4) and a few T-Racks plugins.
The RAM is expandable up to 64bit, currently at 8GB, so I'll at least pop in another 16GB as that's probably all I can afford at the moment. I have a 2nd SSD and the PC takes a 2nd drive, so possibly run audio production on one and record to the other.
My audio interface - I have 2, one is Tascam 16track that records full band, now with Corona - good luck on using that...second one is IK AXE I/O which I am using for the most part.
What do you think? This I am not sure on:
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only);
I have a travel interface that needs power via USB bus and a backup drive that does as well.
Full spec here:
https://support.hp.com/us-en/document/c06655498
i5-10210U (1.6 GHz base frequency, up to 4.2 GHz with Intel® Turbo Boost Technology, 6 MB L3 cache, 4 cores)
Intel® Integrated SoC
Memory, standard
8 GB DDR4-2666 SDRAM (1 x 8 GB)
Video graphics
Intel® UHD Graphics
Integrated
Hard drive
512 GB PCIe® NVMe™ M.2 SSD
15.6" diagonal HD SVA micro-edge WLED-backlit multitouch-enabled edge-to-edge glass, 220 nits, 45% NTSC (1366 x 768)
Realtek 802.11 b/g/n/ac (2x2) and Bluetooth® 5 combo
Expansion slots
1 multi-format SD media card reader
External ports
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI 1.4; 1 headphone/microphone combo;
Minimum dimensions (W x D x H)
35.9 x 24.16 x 2.07 cm
Weight
Starting at 1.92 kg
Power supply type
45 W Smart AC power adapter
Battery type
3-cell, 41 Wh Li-ion
Webcam
HP Wide Vision 720p HD camera with integrated dual array digital microphone
Audio features
Audio by B&O; Dual speakers; HP Audio Boost 1.0
Software
Operating system
Windows 10 Home 64
4TrackMadman
http://www.scrollkeeper.net
