How can I detect audio dropouts without listening to a sinewave for several hours?
Postby shufflebeat » Wed Apr 28, 2021 4:26 pm
I'm testing a couple of recording drives on the Qu Pac and would like to check for dropouts. Logic suggests first recording a sinewave and looking back at the waveform would be straightforward but the Qu doesn't generate sine at inputs, also life is sometimes unexpectedly short so don't want to spend it listening to 500Hz for hours, however perfect it is.
Any thoughts?
I'm in Window Music because any testing setup will be done in W10 (or maybe iPad).
shufflebeat
Re: How can I detect audio dropouts without listening to a sinewave for several hours?
Postby Albatross » Wed Apr 28, 2021 6:05 pm
How about a copy of Audacity and then use the 'search silence' ... you can set the parameters and it will find - the sound - of silence.
Albatross
Postby shufflebeat » Wed Apr 28, 2021 6:24 pm
I like that but I suspect a dropout in this instance wouldn't take the form of actual silence.
shufflebeat
Postby RichardT » Wed Apr 28, 2021 6:37 pm
Why don’t you set it recording something for an hour, then do it again, then null the two files and see if you have any signal.
I’m not sure what a Qu PAC is, so ignore me if that makes no sense...
RichardT
Postby blinddrew » Wed Apr 28, 2021 6:49 pm
Would the kind of drop out we're talking about here trigger a signal spike? If so you could set your sine wave at a low-but-consistently-measurable level (I dunno, -30dB maybe) and leave it playing. If you come back to levels that have a peak much higher up then you know something has glitched?
Postby James Perrett » Wed Apr 28, 2021 8:35 pm
I'd do something like record a sinewave and then do a frequency analysis of the recorded waveform (or just look at it on a spectral display). Any glitches will immediately show up as spikes.
This can be easily done using the JS Tone Generator in Reaper to generate a tone and Reaper's Spectral View to display the result. Other software probably has similar facilities - certainly Adobe Audition can do the same thing.
Postby merlyn » Thu Apr 29, 2021 12:23 pm
James Perrett wrote:I'd do something like record a sinewave and then do a frequency analysis of the recorded waveform (or just look at it on a spectral display). Any glitches will immediately show up as spikes.
The fourier transform of a sinewave is a spike. An impulse (which a dropout is an approximation of and does look like a spike in the time domain) looks like a horizontal line in the frequency domain. An ideal impulse (a Dirac delta) contains all frequencies at an equal amplitude.
Given that a practical digital audio system is band-limited a dropout looks like horizontal fuzz across the whole spectrum in the frequency domain.
merlyn
Postby James Perrett » Thu Apr 29, 2021 1:16 pm
I wasn't clear - on a spectral display in a DAW any glitches show as vertical spikes while the continuous tone shows as a horizontal line. This is opposite to a spectrum analyser view where the tone is a vertical spike.
Postby merlyn » Thu Apr 29, 2021 2:02 pm
I think it's worth remembering that a spectral display has the fourier transform on the y-axis and time on the x-axis with colour being the third dimension of amplitude. Just to keep it all straight in one's head. :thumbup:
merlyn
