Using a vienna template on both, a 2-machine-setup and a 1-machine-setup
For all other computers and operating systems, including Atari, Linux and mobile apps.
Postby Tnecniv » Wed Jun 26, 2019 10:55 am
Hi folks,
I'm working on several pieces of music together with my colleague. We are located in the same building in two different rooms and hence we are using 2 different setups. One setup is using a 2 machine configuration with 2 mac pros from 2012 (master machine running a Cuebase or Digital performer session and slave machine running our VEP orchestral template) and the other setup is using a 1 machine configuration with the trash can mac (the DAW and VEP template both running on the same machine).
Whenever we create a session on either Cuebase or Digital performer on one of the two setups and try to open it on the other setup we run into the following problem: the plugin instances in our DAW don't automatically connect to the VEP template. We have to reconnect the instruments in our through the server interface manually.
Does anyone know of a workaround for this so that the connection between our DAW and the VEP is made automatically upon opening the session irregardless of where on our 2 setups the session has been created?
Thanks in advance!
Tnecniv
