Yoshimi on the Raspberry Pi
Re: Yoshimi on the Raspberry Pi
Postby Folderol » Sat Nov 09, 2019 3:19 pm
It's ALIVE!!!
A hastily snapped picie here.
As you can see it's running multi part, and if you zoom in you can just about see in the CPU monitor the third CPU is running about 43% (the others are little more than idle).
The MIDI file controlling it is included, and does all the part setup as well.
Apologies for the camera flash - I wanted to get this out as fast as possible.
All the software seems to work correctly, but I'll give it a long run and do some more sanity check through the day.
Postby Jumpeyspyder » Sat Nov 09, 2019 3:36 pm
:clap: :clap: :clap: :clap: :bouncy:
Nice work Will - it looks great !!
Jumpeyspyder
Postby Eddy Deegan » Sat Nov 09, 2019 4:21 pm
Folderol wrote:It's ALIVE!!!
Looking great Will, that monitor seems perfect for the task. VERY much looking forward to putting a Yo-Pi through its paces! :thumbup:
Some of my works.
Postby The Elf » Sat Nov 09, 2019 4:29 pm
Postby Martin Walker » Sat Nov 09, 2019 6:02 pm
A further bravo is obviously required, so BRAVO!!! 8-)
Postby Folderol » Sat Nov 09, 2019 6:13 pm
Thanks guys :bouncy:
It's been running for several hours now. The case is getting a little warm, but the centre of the heat is directly above the PSU which is attached to the top. There's no sign of the Pi wanting to throttle due to heat.
One very minor niggle is that it is supposed to be possible to do a system shutdown from Yoshimi by holding down the CTRL key while clicking on the exit icon. It works perfectly on my other machines. Eventually I realised that they were all running with Jack, rather than ALSA. It seems ALSA somehow screws up that combination on exit.
it still works correctly closing from Yoshimi's command line, so should also do so with the correct MIDI NRPN, but I haven't got a file to test that yet - nor a controller with that NRPN set.
The GUI isn't really an issue, because you can just click on the normal exit icon, but I'll try to find out what's going on.
The idea of being able to close down via MIDI, is that you can set everything up, then run it without a mouse, keyboard or monitor and make all your changes via CCs or NRPNs, including a tidy shutdown :)
Postby BJG145 » Sat Nov 09, 2019 6:41 pm
Awesome, nice one Folderol!
Postby Eddy Deegan » Sat Nov 09, 2019 6:59 pm
Folderol wrote:The idea of being able to close down via MIDI, is that you can set everything up, then run it without a mouse, keyboard or monitor and make all your changes via CCs or NRPNs, including a tidy shutdown :)
That's proper thinking-things-through, that is :clap:
The more I look at at the pic, the more I can see a little steampunk paintjob and a few brass fittings on it, but that's definitely one for the end-user, not a suggestion for you!
My money awaits. Just let me know when and where to throw it :bouncy:
Some of my works.
Postby blinddrew » Sat Nov 09, 2019 7:20 pm
Has the potential to open Yoshimi up to a whole new batch of users.
Postby Folderol » Sat Nov 09, 2019 7:37 pm
PM sent!
Postby Eddy Deegan » Sat Nov 09, 2019 8:46 pm
Folderol wrote:
Eddy Deegan wrote:My money awaits. Just let me know when and where to throw it :bouncy:
PM sent!
Reply sent! Wheeeee :D
Some of my works.
Postby ConcertinaChap » Sat Nov 09, 2019 9:00 pm
Me too! I have to say your photo is a GAS magnet!
ConcertinaChap
Postby Martin Walker » Sun Nov 10, 2019 6:08 pm
Eddy Deegan wrote:The more I look at at the pic, the more I can see a little steampunk paintjob and a few brass fittings on it, but that's definitely one for the end-user, not a suggestion for you!
Most definitely!
But you'd also have to rename it the Yosteamy :beamup:
Postby Folderol » Sun Nov 10, 2019 8:38 pm
AHEM
Postby Eddy Deegan » Sun Nov 10, 2019 9:19 pm
I'm currently considering calling mine (for I now own one, hurrah!) something involving "WJGt" (pronounced 'widget') after its creator. It'll be part of a longer steampunk-y name but I'm going to mull that over for a bit.
I can't collect it until the last week of the month as I'm heading to the land of windmills and tulips again this week and next but it'll give me something to think about while I'm away. I am quite excited at the prospect of plumbing it in here :thumbup:
Some of my works.
