Microphones for Ipad
Postby Scouser » Sun Sep 27, 2020 7:27 pm
Can anyone suggest some decent quality mics that would connect direct to Ipad ( Lightning ) It will be used for narration for videos. Initially I was thinking a lav mic, as I could use this sat on the sofa and not be confined to a desk, having said that I’m not crazy bout that lav sound, or at least the ones I’ve tried.
I liked the sound of the AKG Lyra and some of the other mics that were mentioned in the June edition of SOS “choosing a usb mic” Unfortunately it is a desktop.
Is it possible to use an adapter which would allow usb mics to be used with iOS devices ?
Scouser
Re: Microphones for Ipad
Postby Sam Spoons » Sun Sep 27, 2020 7:45 pm
The 'camera kit' can make most USB devices work with an iPad (as long as the power requirement is not too much for the iDevice to supply).
Postby shufflebeat » Sun Sep 27, 2020 8:02 pm
Sam Spoons wrote:...(as long as the power requirement is not too much for the iDevice to supply).
A powered usb hub extends the possibilities further and can often be run from a suitably sized 5v power bank for portable use. I've run a Focusrite Scarlett, an SSL2+ and an Audient ID4 into my iPad for testing purposes.
If that's not too much clutter then pretty much any XLR mic can be used.
shufflebeat
Postby Sam Spoons » Sun Sep 27, 2020 10:15 pm
My Akai EWI USB would not work with me iPads, even with a separate power supply to the power lines on the USB connectors.
Postby shufflebeat » Mon Sep 28, 2020 10:39 am
I'm not a digi-bod in any way but I wonder if the audio i/o system, which at least exists in some form on all devices, is better accommodated than midi. I may try a midi keyboard in the same system and see if it registers.
shufflebeat
Postby Arpangel » Mon Sep 28, 2020 11:25 am
Get a Focusrite Scarlet, some are iOS compatible, that opens up a lot of possibilities, you just need to make sure you can use phantom power.
Postby ef37a » Mon Sep 28, 2020 12:21 pm
The Cirtonics CCU3 USB LDC is really very good. I have experience of two samples now. Very low noise and decent sound quality. My son uses one on classical guitar and for Skype.
