Linux Audio Workstation Build
For all other computers and operating systems, including Atari, Linux and mobile apps.
Postby merlyn » Fri Feb 26, 2021 5:29 pm
I have wondered what kind of performance I would get using Linux with a Ryzen processor for an audio workstation. I decided to find out and went for this spec :
CPU : Ryzen 3900x
Cooler : Noctua NH-D15 SE-AM4
Mobo : MSI B550 Pro
Storage : Adata 1TB Nvme M.2
Case : be quiet Silent Base 601
Power : be quiet Straight Power 11 650W
I'll install Arch Linux on that.
I intend to put something together that will boot and add components as I go along. I already have an 8GB stick of DDR4 and I will use the AMD R7 260X graphics card from this machine I'm typing on to put together enough to boot it.
merlyn
Re: Linux Audio Workstation Build
Postby Folderol » Fri Feb 26, 2021 6:53 pm
Pretty good, I would expect!
I suggest AVlinux, unless you have prior experience of audio under Linux. It gives you a very complete debian-based system 'out of the box'.
https://www.bandshed.net/avlinux/
Yes. I am that Linux nut.
Postby flozzi001 » Tue Mar 23, 2021 6:59 pm
Wow sounds like a really nice Idea.
I would be happy to hear if it is working out.
I wonder what DAW and interface you are using?
flozzi001
Postby billc2 » Tue Mar 23, 2021 9:21 pm
I see Planet CCRMA is still going. That was really good last time I did a Linux Audio system.
billc2
