Drummer needing help with Logic Pro x
• Page 1 of 1
I am using logic pro x with my drum module, but I can't figure out how to adjust the cross talk in logic pro to stop other sounds from triggering when I don't hit them. For example I will hit my floor tom and it will trigger the cymbal from the vibration of hitting the tom. Does anyone know how to fix this in logic pro? Thank you
- dustin@renewed.church
Dustin
Re: Drummer needing help with Logic Pro x
Do you mean you are physically hitting a pad, and the vibration is causing another pad to trigger?
If so, this is not something you fix in Logic, the drum kit should have settings for various cross-talk sensitivity thresholds etc.
Once a note is sent via MIDI, there's no way Logic can determine that a D1 note with a velocity of 34 is a soft hit from you, or a vibration-induced hit the pad has generated.
Sure, you can eliminate low velocity hits, but that just removes your ability to express your self with grace notes etc.
desmond - Jedi Poster
