Vox AC30 - GSH12-30 vs Celestion AlNiCo
Re: Vox AC30 - GSH12-30 vs Celestion AlNiCo
PostPosted: Fri Jan 18, 2008 8:53 pm
by Mark Dagger
The lack of Blue speakers in your AC30 wont stop you getting the sound you are after. But, as a worthy alternative, make sure you go for the Celestion Greenback G12 speaker. These are more "bluesy" and slightly warmer - they may even suit your sound better.
The Blue speakers are quite brittle when cranked up (they CAN be harsh) but very papery and creamy soundind at the same time.
If you want that Jimmy Page sound, you're probably looking at either using the "Bright" channel with some kind of Booster or, the Normal channel with a Treble Booster. Most of the 70's guitar players (Clapton, Page, May, Gallagher etc) achieved there sounds with Treble Boosters.
Cheers.
PostPosted: Fri Jan 18, 2008 10:57 pm
by mike79
i have an ac30 with blues and feel they are better and worth the money. You may have problems though to begin with as i have. They come with cheap chinese valves and mine didn't last more than a few months before changing. The grill can start to come away and need reglueing in and the reverb (on mine anyway)was rubbish from day one. Didn't realise at first but on checking two of the springs in the tray had come out. im getting an accutronics replacement. Dont mean to moan as it is a quality amp but you pay enough money so should get quality build too.
PostPosted: Fri Jan 18, 2008 11:16 pm
by Steve Hill
You'll pay as much for Greenbacks as you will for Blues, and they'll be re-issues. A bit expensive if you have to replace the two speakers which come with the AC30.
There are Greenbacks and Greenbacks, with originals changing hands for hundreds of dollars, and a (pretty strong) school of thought that says the reissues are not as good.
For a brain-numbingly tedious analysis of Greenbacks past and present, see here.
PostPosted: Sun Jan 20, 2008 12:45 am
by thesilentdawn
Weber VST sell 12" alnico blues as well...
https://taweber.powweb.com/weber/
PostPosted: Sun Jan 20, 2008 2:58 pm
by KolonelKasper
thanks all!
lots of help, cheers :)
PostPosted: Sun Jan 20, 2008 4:40 pm
by vinnyburns
KolonelKasper wrote:thanks all!
I have the Custom Classic cc2x with the blue speakers and I love them. Well worth the extra money.
It has been in for repair twice since I have had it. Basically though it was the same problem and was sorted out the second time. The Rectifier valve heater was seeing way above the 5v it needed from the transformer. This resulted in the rectifier blowing. After blowing a lovely old Mullard replacement from the first repair, the problem was sorted out. Love the sound of this amp.
A really good booster to get for it is the Bad Bob Booster available from analogman.com. It's very quiet considering the amount of gain it has and sounds sweet with the AC30.
All the best.
Vinny.
PostPosted: Tue Jan 22, 2008 7:29 pm
by thesilentdawn
All the best.
Vinny.
That's why I won't buy a Vox now. Reliability is a problem. It was with the TBX UK-made amps and it is now with the Chinese amps.
PostPosted: Wed Jan 23, 2008 12:49 am
by vinnyburns
Reliability has always been a problem with ac30's lol Sounds great though.
All the best.
Vinny.
PostPosted: Tue Feb 05, 2008 1:37 am
by thesilentdawn
Oh, undoubtedly so but there's a level of failure that goes beyond 'needs regular servicing' and enters the camp marked 'Vox use too many cheap shitty components'. I'll give a quick hello to the Vox Cambridge that lasted 20 minutes this weekend after being unwrapped :)
PostPosted: Tue Feb 05, 2008 10:26 am
by IvanSC
So - I have a G12S 20 watter from the Rola Celestion Ipswich Suffolk days.
Where does that fit into the scheme of things?
Also the earliest Celestions I ever saw WERE labelled Rola Celestion & were made in London.
Go figure....
PostPosted: Wed Feb 06, 2008 5:10 am
by zenguitar
OK !!!
I'll give you a fiver for it Ivan!!
PostPosted: Wed Feb 06, 2008 10:49 am
by IvanSC
zenguitar wrote:OK !!!
Is that a real British fiver, or a Eurofiver?
So what can you tell me about the speaker, apart from I reckon when I finally get the cabinet made for the Deluxe it will be the ideal speaker, since I can`t afford a Weber or similar.
The amp sounds so good already even through the Session bass cab I am using I can`t wait for the rain to stop s0o I can get in the shed and make the box!
I even have some nice old 23mm pine board.
PostPosted: Thu Feb 07, 2008 3:07 am
by zenguitar
Ivan..
Britfiver, Eurofiver, Usafiver..
No special knowledge, just sounds collectable so worth trying to pull a fast one ;)
PostPosted: Thu Feb 07, 2008 9:49 am
by IvanSC
You smooth talking bar steward, you! Alright, you an have my Fender 12" speaker for a fiver plus postage. Did I mention it had a fried voice coil? Gives it that extra crispy sound.... Think I`ll keep the celestion though.
8-)
PostPosted: Fri Feb 08, 2008 1:12 am
by zenguitar
Would that be a Session 4x10 bass cab matey?
I used to have a Session 4x10 guitar cab and a really regret trading it.
