Guitar wiring question
Re: Guitar wiring question
Postby forumuser746386 » Thu Apr 10, 2008 10:54 am
Cheers guys. I think the answer to wiring it is to change the tone to a volume pot and use two seperate voulmes. i wouldnt use the tone much anyway. the other toggle switch i am assuming is a phase switch. how could i roll this in to the circuit?
forumuser746386
Postby Parker Fly » Thu Apr 10, 2008 11:20 am
Mixing passive and active will give you major headaches, not least the interference from the active circuit when you're playing the passive pickups. The field on a passive pickup will interfere with the active circuitry too, and the very instant you go near an amp/anything electrical, you'll get hum to high hell.
Parker Fly
