How do I achieve this ???
Postby Simon2008 » Wed May 07, 2008 9:15 pm
Can anyone suggest a solution for this problem:
I'm stumped :?
The guitarists will be in the cellar with the drummer but the amps are 15m away in various rooms upstairs for seperation.
How can I get a good clean signal to the amps, knowing that 15m is too long for a jack lead to work properly?
any help would be great
thanks
Simon2008
Re: How do I achieve this ???
Postby Wonks » Wed May 07, 2008 9:47 pm
Basement Jacks (pun intended) into active DI box. Balanced cable to an active DI box by the amp. Jack cable from DI box to amp. You may be able to hire some DI boxes from a PA company if you aren't going to be doing it enough to make it worthwhile buying your own.
Alternatively, a good quality radio lead may work quite well at that distance - but it depends on the house/basement construction. Thick stone or reinforced concrete may soak up too much signal for it to work.
Postby MadManDan » Wed May 07, 2008 10:46 pm
you could just re-amp Much has been said on these forums about it. Record it dry with a reference sound to monitor with, then send it out to an amp later after the drums are done
MadManDan
Late '14 mini 3 GHz i7 16 GB
Hi Sier 10.13.3. Glyph atomic. FF Scarlet 18i8.
Sup Drum 3. Pro Tools 2019.6.0.  iCon iKb 8x.
Mics, spkrs, 'phones, gtrs, greedy cat
Postby Dan LB » Wed May 07, 2008 10:54 pm
If you are using heads/cabs keep the amp heads in the basement with the guitarists and extend the SPEAKER cable to the cabs.
Dan
Dan LB
Postby Microwave » Thu May 08, 2008 7:04 pm
Dan LB wrote:If you are using heads/cabs keep the amp heads in the basement with the guitarists and extend the SPEAKER cable to the cabs.
Dan
That makes a lot of sense to me.
Microwave
