Build project - resonator guitar from recycled bits
Re: Build project - resonator guitar from recycled bits
Postby adrian_k » Fri Mar 09, 2018 2:56 pm
Next - purfling and binding. Not a nasty bowel bowel affliction as implied by Wonks earlier ;) but annoying thin bits of wood that need to be bent to shape and glued round the edges..
In line with the re-use/recycle ethos of the project we delved into the 'this might be useful one day' bin and found a strip of purfling that Colin thinks he made about 27 years ago, and two slightly different binding strips left over from other guitar builds. The purfling is Bubinga or rosewood in a boxwood sandwich. One of the binding strips is rosewood with a boxwood trim, the other rosewood with beech.
Cutting the purfling to size:
Unfortunately, probably due to its age, one of the strips lost some of its boxwood on one side in a few places. Luckily Col had some boxwood veneer offcuts that I could use to patch it up.
adrian_k
getting better all the time..
Postby adrian_k » Fri Mar 09, 2018 3:56 pm
Next I need to cut a channel round the edge for the purfling. Allowing space for purfling plus binding, using a purfling cutter I score a deep line round the top.
Then I rout round the edge almost to the scored line.
Next I clean up the routed channel with a chisel and finish off with a file.
adrian_k
Postby adrian_k » Fri Mar 09, 2018 4:11 pm
I can't avoid it any more, I'm going to have to bend some wood. Colin heats up the iron and does the first bit of purfling to show me how easy it is, haha.
I bend the second bit and the layers start to separate out in places (maybe getting it too hot?) Then on the sharpest corner the boxwood separates and splits on both sides leaving just the centre strip for a couple of inches. Don't worry says Col, you can glue that back together as you go. That particular corner is jinxed, it's where I split the top earlier..
Here's some old bloke breaking some wood:
adrian_k
Postby adrian_k » Fri Mar 09, 2018 4:18 pm
Then it's just a case of working round the guitar in small sections, gluing and pinning the purfling tightly in place. Anywhere the boxwood has come away I glue back together as I go, including the bits that completely split away.
Here it is all glued and pinned. The tape is just providing extra support where the purfling split.
And here it is with the pins out. The middle pic shows 'problem corner'. Not too bad, but the centre strip does look a bit thicker there now. The outer pics were taken after routing again for the bindings, hence no pinholes.
Now, as I said last month - "Next month, binding"........
adrian_k
Postby Wonks » Fri Mar 09, 2018 5:27 pm
You could simply have made the whole guitar out of glue! ;)
Well done Adrian. Just keep going and you'll get there in the end.
Postby Watchmaker » Fri Mar 09, 2018 5:31 pm
Wow!
I just caught this thread. I'm amazed at your good fortune and skill!
I've been avoiding doing a guitar build for years, but this is totally inspiring. Time to order that thumb plane and 476 pins...
Cheers for sharing this with such grace, as far as the corner of the damned goes - the gods demand a sacrifice either in blood or pain. I see you're wise enough to give it gladly.
When you're done please post a recording of it somewhere like sound cloud so we can hear its voice.
Watchmaker
Postby adrian_k » Fri Mar 09, 2018 6:16 pm
Wonks wrote:You could simply have made the whole guitar out of glue! ;)
Yes but what would I use to stick the glue together? :headbang:
adrian_k
Postby adrian_k » Fri Mar 09, 2018 6:29 pm
Watchmaker wrote:I've been avoiding doing a guitar build for years, but this is totally inspiring. Time to order that thumb plane and 476 pins...
Go for it! If you do though you might want to go to a thumb gym first, all that thumb planing and pinning I can’t play barre chords at the moment :bouncy:
adrian_k
Postby Guest » Fri Mar 09, 2018 6:38 pm
Yeah, you're doing a great job. Most fascinating following your adventure!
Guest
Postby Folderol » Fri Mar 09, 2018 10:14 pm
I always enjoy reading about these projects. I can't see me doing anything like that myself, but it's great to read how people find and overcome problems. :bouncy:
Postby Wonks » Fri Mar 09, 2018 11:02 pm
He's got it easy. He's got all the expensive tools to hand, plus a brother who definitely knows his onions (and guitars).
Postby adrian_k » Sat Mar 10, 2018 2:18 pm
Yes having access to the tools means I can get things done quicker, which is important since I’m only working on it a day a month. The main thing though is having a good teacher with nearly 30 years experience of making and doing major repairs on all types of stringed instruments.
If I lived closer I’d just join his evening class. If there were any spaces that is..
adrian_k
Postby adrian_k » Fri Apr 20, 2018 12:59 pm
Right here we go with the April progress report. First off I had a spare half hour between sanding finishes for Col so I started on the neck. This was made by Hofner some time in the early 70s and has never been on a guitar. Col bought a job lot of ex-factory stock, used the others but this one has been hanging on the wall for years. The rosewood fingerboard is looking a bit sun-bleached:
adrian_k
To make this usable for me I'm going to have to put a heel on it, attach a perch pole, get rid of the zero fret and replace with a nut (could keep it I guess but don't want to), and refret it with some slightly meatier frets. So, frets out:
I was surprised that the fingerboard wasn't more dried out, I was expecting more collateral damage from removing the frets, but they came out clean as a whistle. Which was nice.
The dots are cheap white plastic so I might drill them out and put some pearl-like ones in, depending on how brave I'm feeling. I'll also get a decal done - maybe 'Frankenbro'... hmmm...
adrian_k
Postby Sam Spoons » Fri Apr 20, 2018 11:16 pm
adrian_k wrote:Right here we go with the April progress report. First off I had a spare half hour between sanding finishes for Col so I started on the neck. This was made by Hofner some time in the early 70s and has never been on a guitar. Col bought a job lot of ex-factory stock, used the others but this one has been hanging on the wall for years. The rosewood fingerboard is looking a bit sun-bleached:
I bought an ex Hofner body, sort of 135 style an while ago, decided it wasn't for me in the end and my pal Brian Eastwood built it into a really nice ES135/Hofner for another friend of mine using an original Hofner neck, Turned out to be a really nice and unique guitar for Squier money.
