Build project - resonator guitar from recycled bits
Re: Build project - resonator guitar from recycled bits
Postby Hewesy » Mon Nov 12, 2018 4:06 pm
Wow that looks like a brilliant repair, I'd be very happy with that!
As an aside I've just done something similar to fill holes in brickwork. I've no idea why the previous owner felt the need to drill quite so many holes for a light fitting but with clear silicone and some red brick dust, much tidier.
Hewesy
Hewesy
Postby Albatross » Mon Nov 12, 2018 4:51 pm
Martin Walker wrote:
adrian_k wrote:I filled the damaged area around the snowflake with superglue and rosewood dust. Where that hadn't filled completely I pushed in some coloured wax. Not great but if you don't look too closely....
That looks great to me Adrian - it's amazing what sawdust and glue can do for you, isn't it? (answers on a postcard please, to the usual address ;) )
It does look nice. I recently acquired an old 70s Fender 12 string from a local shop for a song. It needed a lot of work and like a lot of old mistreated 12s a lot of meat off the bridge.
The chisel slipped :? But on closer inspection it had formed the shape of a small almost perfect arrow-head. So I filled it with bone dust and superglue and it came up a treat.
So if you ever see a Fender 12 with a bone arrow inlay just below the bridge... that's mine.
Its a feature, as they say in the building trade.
Albatross
Postby adrian_k » Mon Nov 12, 2018 5:19 pm
Alba wrote:Its a feature, as they say in the building trade.
It’s these ‘features’ that make instruments unique and interesting I guess. And at the end of the day it’s really about how they play and sound anyway.
adrian_k
getting better all the time..
Postby adrian_k » Sun Dec 09, 2018 9:27 pm
December's workshop visit report..
Time to start fitting the neck to the body. First off I have to cut a mortice in the heel to receive the perch pole. After marking out the position I removed a fair bit of the wood using a forstner bit in a pillar drill, setting the stop for 20mm.
adrian_k
Postby adrian_k » Sun Dec 09, 2018 9:29 pm
I then chiselled out the remaining wood until the perch pole fitted:
..and then test fitted the whole thing:
adrian_k
Postby adrian_k » Sun Dec 09, 2018 9:34 pm
Then it was a case of slowly taking down the heel using whatever worked best (small plane, chisel, file), maintaining the angle as measured between the top and the sides, until the heel fitted snug against the body. Nearly there:
It's just a case of test fitting, taking off a tiny bit more wood from the heel, or from any parts that are stopping the neck from fitting snug. Just a little bit more to do, but I ran out of time and I learned my lesson from last month trying to get too much done in a hurry ;)
adrian_k
Postby blinddrew » Sun Dec 09, 2018 9:36 pm
Looking good. :)
Postby zenguitar » Mon Dec 10, 2018 12:55 am
Won't be long until you are stringing up and playing :D
liberté, frivolité et vanité
Postby adrian_k » Mon Dec 10, 2018 10:06 am
zenguitar wrote:Won't be long until you are stringing up and playing :D
Hope so Andy. Feels like ages since I started this, just want to get it done now!
adrian_k
Postby Folderol » Mon Dec 10, 2018 12:42 pm
Ah!
The most dangerous phase of any long-term project. be careful.
Postby adrian_k » Mon Dec 10, 2018 5:32 pm
Ah!
Hopefully learned my lesson last month, wood has its own ideas about how things will go...
adrian_k
Postby adrian_k » Sat Feb 09, 2019 11:38 am
Back to the workbench at last, having missed a trip in January.
Last trip I had got the heel/body joint to somewhere within spitting distance:
I thought I wouldn't have much more to do to get the neck on, well I guess it's better to be optimistic otherwise I probably wouldn't have started this. However. The maple on that heel is like rock, trying to to take off small amounts in a controlled way is a bit above my skill/experience level. See how white the knuckles are:
adrian_k
Postby adrian_k » Sat Feb 09, 2019 11:47 am
But I got there in the end. Next thing was to see how it all lined up. I clamped the neck in place then screwed through the fingerboard into the block under the top. (Managed to drill through the fingerboard when I was recessing one of the screw heads so needed to patch that - ho hum).
Then checked the centre line on the fingerboard to the one at the tail end of the body. Close, but not quite there:
Another round of removing small shavings, filing, sanding, test fitting until it's all lined up. Great!
adrian_k
Postby adrian_k » Sat Feb 09, 2019 12:11 pm
Now I had to check the action/neck angle. With the neck clamped in place I fitted the cone and spider and using a long rule between the bridge and the nut position measured the distance above the fingerboard around the 12th fret:
I had just over 5mm, or about 4mm above the frets when I eventually fit them. Even though I want a high action for (mostly) playing slide that'll be too much once the saddle is fitted, even allowing for string pressure compressing the cone. The neck is too flat to the body, I need it angled back slightly.
So, another round of removing small shavings from the rock hard heel, filing, sanding, test fitting until I have just under 3mm above the fingerboard at the 12th. It's a judgement call at this point whether to take more off but I decide to go with it.
adrian_k
Postby adrian_k » Sat Feb 09, 2019 12:14 pm
Finally, what's the scale length like? If I've positioned the cone correctly I should have ended up with 642mm at the saddle. Seems like a long time ago that I made these measurements...
.... but all looks close enough. So Now I can glue the neck to the perch pole.
adrian_k
