Build project - resonator guitar from recycled bits
Re: Build project - resonator guitar from recycled bits
Postby Martin Walker » Fri Nov 24, 2017 4:53 pm
Oh, that is SO beautiful Chris - another round of applause for Col! :clap:
Postby adrian_k » Fri Nov 24, 2017 8:06 pm
That’s a beaut Chris. What is the wood used for the body?
Supplementary question - do you have a pickup fitted and if so which one?
adrian_k
getting better all the time..
Postby Wonks » Sat Nov 25, 2017 12:08 am
It's actually a papier-mâché body made from £50 notes Chris found under his mattress.
Postby Guest » Sat Nov 25, 2017 2:12 am
adrian_k wrote:That’s a beaut Chris. What is the wood used for the body?
Hi Adrian.
I think it's maple. No pickup, I mike it up with a pair of Royers.
Guest
Postby Guest » Sat Nov 25, 2017 2:13 am
Wonks wrote:It's actually a papier-mâché body made from £50 notes Chris found under his mattress.
:) The only thing under my mattress is my secret horde of After Eight's.
Guest
Postby adrian_k » Sat Nov 25, 2017 9:32 am
ReadySaltedChris wrote:Hi Adrian.
Yes of course I realised soon after I posted it looked like figured maple. Definitely not £50 notes, although maybe could have been tenners in the days before plastic.
I’m going to try a McIntyre ‘feather’ pickup. I’ve got one in my mandolin and am really happy with it.
adrian_k
Postby Guest » Sat Nov 25, 2017 2:21 pm
Did you make the mandolin yourself too?
Guest
Postby Wonks » Sat Nov 25, 2017 3:26 pm
No, Colin made that for him. It's very nice, I played it once some time ago.
Postby Guest » Sat Nov 25, 2017 5:47 pm
Wonks wrote:No, Colin made that for him. It's very nice, I played it once some time ago.
I think I might ask Col to make me one. I am inspired!
Guest
Postby Wonks » Sat Nov 25, 2017 7:43 pm
You can always put your name down on the waiting list!
Postby adrian_k » Sun Nov 26, 2017 9:17 am
As Wonks said Colin made it. I got it cheap as it’s made from offcuts! This Frankenbro thing is the first thing I’ve attempted to make.
adrian_k
Postby Rich Hanson » Wed Nov 29, 2017 9:45 am
Not any more
*burp*
Rich Hanson
Postby Longsight John » Thu Dec 07, 2017 11:00 pm
Longsight John
Postby adrian_k » Sun Dec 10, 2017 10:51 am
OK here's December's workshop visit report...
Last month I started reinforcing the top. This month more of the same. I completed the cone hole reinforcement and added a patch where the two grills will go. This pic shows the new patch in place and a brace being glued.
Just for grins I dropped the cone in the hole for a pic:
adrian_k
Postby adrian_k » Sun Dec 10, 2017 11:02 am
Then on with the bracing:
The top picture shows a brace being glued just before the neck block. You might notice that I forgot to put a ruler behind the joint to help spread the pressure - this is what happens when you are fitting in with other jobs and in a bit of a hurry. Looks OK though as I used plenty of clamps. The diagonal braces are just placed in position for the top photo, they are being glued in the bottom one. There will be another three braces - one lateral brace just in front of the cone reinforcement, and two more diagonals around the hole.
adrian_k
