Build project - resonator guitar from recycled bits
Re: Build project - resonator guitar from recycled bits
Postby adrian_k » Sun Dec 10, 2017 11:18 am
When I started the project I thought it probably wouldn't be worth spending a lot of money on hardware, on the basis that if the guitar turned out OK but would benefit from better hardware I could always upgrade.
So I took a punt on some very inexpensive bits from China. Cone (not pictured), cover, spider, tailpiece, bridge and grills all for £45:
The cone was a cast one so not very good, which is OK as I already have a spun cone from a Dobro, albeit slightly damaged. The spider, cover, tailpiece and grills seem OK. Might try the bridge but it would be easy enough to make one.
adrian_k
getting better all the time..
Postby adrian_k » Sun Dec 10, 2017 11:30 am
A last pic from the workshop - a couple of guitars being worked on.
The one on the left is a Keefe guitar from 2011, in for a setup. It's quite plain looking but has an amazing sound. It's not subtle, but fantastic for fingerstyle blues - fast, clean, focused, balanced and punchy.
The one on the right, the body of the Taylor was smashed somehow and the owner asked Colin to make a new one.
adrian_k
Postby Martin Walker » Sun Dec 10, 2017 5:00 pm
You certainly keep busy Adrian! :clap:
Postby Wonks » Sun Dec 10, 2017 9:59 pm
Nice stuff, Adrian.
Next time...
"And here's one we produced earlier". ;)
Postby Guest » Thu Jan 25, 2018 11:17 am
Hey Adrian,
I found the pikkies Col sent me when building the dobro. I uploaded them to FB in case you're interested...
https://www.facebook.com/media/set/?set=a.393847744404600.1073741842.100013381338296&type=1&l=71cc20cc2f
Guest
Postby blinddrew » Thu Jan 25, 2018 11:39 am
That is rather gorgeous.
Postby adrian_k » Thu Jan 25, 2018 7:28 pm
Chris, lovely stuff, thanks for that :D
I’ll be seeing Col next week, I’ll say hi..
adrian_k
Postby Guest » Thu Jan 25, 2018 8:16 pm
adrian_k wrote:Chris, lovely stuff, thanks for that :D
Yeah, please do. Tell him it's sounding great! (I use it alot for strumming stuff too as it records better than my Martin).
Look forward to hearing yours.
Guest
Postby adrian_k » Sat Jan 27, 2018 7:16 pm
Me too but it may be some time... a day a month means slow progress. Ah well.
adrian_k
Postby adrian_k » Fri Feb 02, 2018 6:15 pm
January progress report....
Have now finished bracing the top. The basic scheme is lateral brace behind the hole, lateral brace in front of the hole, lateral brace in front of the grills, reinforcement around the hole, diagonal bracing around hole. The rear diagonals lie alongside the reinforcement and notch into the sides. The front diagonals lie on to of the reinforcement, lap over the rear diagonals and notch into the front lateral brace. Got it?
It feels very stiff (the guitar top...)
adrian_k
Postby adrian_k » Fri Feb 02, 2018 6:27 pm
So now there is nothing for it but to glue the top on. Now where did I put the guitar body?
As with the back I have to plane the lining and front and back blocks down to provide a nice gluing surface. Then cut notches in the sides for the brace ends, making sure that the centre line on the top aligns with the centre line of the body. A quick dry clamping to make sure everything fits and is aligned, then out with the Titebond and soft clamps.
With some help from my beautiful assistant I first clamp over the brace ends..
And here are all the clamps in place..
adrian_k
Postby adrian_k » Fri Feb 02, 2018 6:29 pm
And finally, clamps off and everything looking good...
Next month - binding.
adrian_k
Postby Wonks » Fri Feb 02, 2018 6:41 pm
adrian_k wrote:Next month - binding.
Try syrup of figs. ;)
All very good work, Adrian.
Postby zenguitar » Fri Feb 02, 2018 6:54 pm
Yep, looking good :thumbup:
Yogi Berra
Postby Folderol » Fri Feb 02, 2018 7:15 pm
Mmm, that really is looking rather pretty :thumbup:
