Has anyone tried the new-ish Celestion V-type speakers ?
Postby SecretSam » Sun Sep 10, 2017 1:44 pm
And if so, do you have Firm Views on their merit or otherwise ?
SecretSam
Re: Has anyone tried the new-ish Celestion V-type speakers ?
Postby ef37a » Mon Sep 11, 2017 9:04 am
http://thefretboard.co.uk/discussion/co ... nt_1618176
They LOVE 'em!
I trust it is ok to copy in links to other forums?
Postby Random Guitarist » Mon Sep 11, 2017 3:11 pm
I have a V-Type and a greenback in a 2x12 open back cab. Both sound very fine.
The cab is wired to allow me to play either or both so I can compare. The V-Type is a bit clearer/crisper, I sometimes find it a bit sharp on it's own, but I'm inclined to mellowness. The pair together though, that definitely hits the spot. YMMV
Random Guitarist
Postby SecretSam » Mon Sep 11, 2017 7:54 pm
Wow: an actual A-B test !
Thanks Dave and Random.
SecretSam
Postby Wonks » Mon Sep 11, 2017 8:57 pm
SecretSam wrote:Wow: an actual A-V test !
FTFY.
Postby SecretSam » Tue Sep 12, 2017 8:25 am
I see what you did there.
Badum.
and Tish.
SecretSam
Postby ef37a » Tue Sep 12, 2017 10:32 am
Shouldn't that be 'FIFY'?
Postby Wonks » Tue Sep 12, 2017 10:34 am
Always used 'that' rather than 'it'.
Postby SecretSam » Tue Sep 12, 2017 11:40 am
And shouldn't it be G-V testing ?
SecretSam
Postby Wonks » Tue Sep 12, 2017 11:56 am
Yes , it's the most literal adaption but in my own little world of Wonky logic, no.
V rhymes with B, but G doesn't rhyme with A. You also move a bit too too far away from the original 'A-B testing' to keep the best continuity.
Postby SecretSam » Wed Sep 13, 2017 7:04 am
I stand corrected.
Didn't there used to be a TV programme called Jim'll FIFY ? It all ended rather badly, I believe. Presumably Jim mis-interpreted one of the Fs.
SecretSam
Postby SecretSam » Fri Sep 15, 2017 8:53 pm
In a moment of insight, I visited the Matamp website.
Matamp use them in lots of their cabs, which is the highest praise I can imagine.
By 'eck.
SecretSam
