Adhesive pads for guitar
PostPosted: Sun Feb 25, 2018 12:13 pm
by BJG145
A while ago I picked up an ACPad that was going cheap; a rubber MIDI-controller overlay designed to stick on an acoustic guitar. Unfortunately the sticky pads it uses are no longer sticky enough, and I haven't been able to get a replacement set yet.
I was wondering if anyone could suggest some other double-sided sticky thing that could be used to fix something securely but temporarily to the top of an acoustic...? While I wouldn't want to damage the surface, I don't mind about minor marks.
Re: Adhesive pads for guitar
PostPosted: Sun Feb 25, 2018 12:43 pm
by Wonks
I would suggest trying light tack masking tape and superglue. It's a luthier trick for sticking sandpaper to radiusing blocks (and similar). Stick the masking tape to the guitar to cover the area under the pad. Repeat for the underside of the pad. Carefully spread superglue over the masking tape on the guitar (you probably want to do this outside as superglue in any quantity produces nasty fumes). Don't overdo it as you don't want the glue spreading on the guitar, so leave a band round the edges with no glue on. You can get an accelerant spray for superglue, (which is recommended in this case), which you spray on the glue, then put the pad on top and press down.
The tape is now joined back to back with the superglue and although light tack, provides enough grip overall to keep the pad securely in place. It's certainly strong enough to keep sandpaper in place when sanding a fretboard. But it still allows you to prise the surfaces apart with a spatula/scraper. You may still need to use some glue remover after you've pulled the tape off, but there shouldn't be any permanent marks left.
I suggest trying it out on some scrap wood first.
Demoed here. https://www.youtube.com/watch?v=ub6PsY4cgwg
PostPosted: Sun Feb 25, 2018 7:16 pm
by BJG145
Thanks Wonks, that's an interesting hack.
PostPosted: Mon Feb 26, 2018 2:04 pm
by Studio Support Gnome
BJG145 wrote:Thanks Wonks, that's an interesting hack.
i've done similar in the past by using 2 inch wide masking tape, with 1 inch wide self adhesive velcro in the middle of it ... as long as you're careful it makes the thing removable and replaceable , often handy if the instrument has to go in a hard case.
PostPosted: Sun Jul 08, 2018 2:39 pm
by BJG145
Finally got round to trying this - works a treat. :-)
PostPosted: Sun Jul 08, 2018 2:50 pm
by blinddrew
A portable one-man band. Any video/audio footage of it in action? :)
PostPosted: Sun Jul 08, 2018 3:07 pm
by BJG145
...ah, it was Wonks' suggestion that I was referring to. No, so far I've been content just to prop it up in a dark corner with the lights on and admire it.
The Kickstarter originator Robin Sukroso has made some nice demos with it...
https://www.youtube.com/watch?v=w2S0o4Sjwis
Think I'll start simple with a couple of synth effects on Echo Beach at the local jam night tomorrow.
PostPosted: Mon Jul 09, 2018 12:52 am
by Martin Walker
BJG145 wrote:The Kickstarter originator Robin Sukroso has made some nice demos with it...
Now that's an impressively versatile creation! :clap: :thumbup: 8-)
