Guitar pedal PSU
Re: Guitar pedal PSU
Postby Jumpeyspyder » Thu May 17, 2018 1:16 pm
something like this ?
https://uk.rs-online.com/web/p/isolated ... s/1620652/
(with a the right knowledge and tinkering talent)
It might even be possible to retrofit these to an existing none isolated supply ?
Jumpeyspyder
Postby Kwackman » Thu May 17, 2018 1:20 pm
Jumpeyspyder wrote:something like this ?
In case you missed it, the minimum order is 25 units.
Kwackman
Postby Jumpeyspyder » Thu May 17, 2018 1:25 pm
this one then :)
https://uk.rs-online.com/web/p/isolated-dc-dc-converters/6894781/
Jumpeyspyder
Postby ef37a » Thu May 17, 2018 1:27 pm
Folderol wrote:
ef37a wrote:Another tack occurs? Instead of an expensive custom multi windings transformer maybe a good quality 10V (say) 4 amp SMPSU line lump then a collection of DC-DC converters? These are very clean and reliable and not that expensive now.
Mr Orchid, are you watching?
Ummm.
That's pretty much what I was suggesting :o
Oh! SORRY! I thought you meant a rake of wall rats mate?
Postby ef37a » Thu May 17, 2018 1:57 pm
Ummm.
SORRY! Did I misread? I thought you were suggesting a rake of wall rats?
BTW, thought I posted this 1/2hr ago?
Postby James Perrett » Thu May 17, 2018 2:09 pm
Or the one at
http://uk.farnell.com/xp-power/ie1209s/ ... dp/2536046
which is both reasonably priced and available immediately (although I've not checked the data sheet for any gotchas).
Postby Folderol » Thu May 17, 2018 4:24 pm
These would be fine for the lower powered pedals, but you might have to go up to a 5W rating for the greedier ones.
This sort of thing is used extensively in industrial electronics these days where odd isolated supplies are needed. Isolation voltage is usually 5kV or at least 1kV and they are usually S/C proof.
P.S.
Farnell often have a better range and availability than RS
Users browsing this forum: Wonks
