Ported speaker cabinet design and speaker frequency response curves
Re: Ported speaker cabinet design and speaker frequency response curves
Postby Wonks » Sun Oct 21, 2018 1:30 pm
I've had a MarkBass Little Mark 250 through the same cab and it didn't sound much different. I've also heard the TC Combo version of mine and it didn't sound significantly different to any of the other 15" combos around the same price point that my mate was testing in Andertons at the time. So a mixture of the bass and amp settings I'd assume.
Postby Kwackman » Sun Oct 21, 2018 1:56 pm
All images load, in situ in the post, with no extra action here.
(Mac, Safari)
Kwackman
Postby Wonks » Sun Oct 21, 2018 2:22 pm
I think they are 4-5 Meg B images, so may take a while to show themselves.
Postby ef37a » Sun Oct 21, 2018 3:31 pm
Wonks wrote:I think they are 4-5 Meg B images, so may take a while to show themselves.
Nope. Twizzle then still "Image failed to load" I didn't generally have a bother will check elsewhere.
Postby Sam Spoons » Sun Oct 21, 2018 3:59 pm
Wonks wrote:I've had a MarkBass Little Mark 250 through the same cab and it didn't sound much different. I've also heard the TC Combo version of mine and it didn't sound significantly different to any of the other 15" combos around the same price point that my mate was testing in Andertons at the time. So a mixture of the bass and amp settings I'd assume.
Yes, seems most likely...
Postby Martin Walker » Tue Oct 23, 2018 4:03 pm
Love that cab finish wonks - very retro! :thumbup:
Postby Wonks » Tue Oct 23, 2018 6:43 pm
The first lot of (water based) varnish didn't adhere to the wood, apart from in a few places where it stuck very well indeed. I'd just started to sand it flat prior to polishing and it came off in sheets. The outer veneer of Meranti on the ply then sanded through in places when I was getting it off and getting the surfaces level again, so it looked very patchy. I was then just going to paint it a solid black, but then changed by mind and re-stained it and then used yacht varnish for a warts and all look.
Postby Martin Walker » Wed Oct 24, 2018 4:53 pm
Wonks wrote:I was then just going to paint it a solid black, but then changed by mind and re-stained it and then used yacht varnish for a warts and all look.
I would describe it as 'hand-crafted retro' rather than warts and all' ;)
Postby Wonks » Wed Oct 24, 2018 5:43 pm
Well, it originally didn't have any of those sanding marks on the top, but when I re-stained it, I did a black stain first then rubbed it back a bit and then did the brown, which highlighted those marks (left from getting the few stuck patches of old varnish off. Sanding those marks away wouldn't have left any of the original facing veneer on the top, so I left them.
Postby Martin Walker » Thu Oct 25, 2018 1:27 am
Don't give all your secrets away Wonks - I said I LIKE it ;)
