Screening / Shielding a Rear Routed Strat
Re: Screening / Shielding a Rear Routed Strat
Postby Jay Menon » Tue Sep 25, 2018 3:05 pm
Problem solved - shielded the pickup cavities as you guys recommended...
For each pickup cavity
- One strip of foil affixed to floor
- Rest of floor and walls painted with graphite paint (overlapping onto foil for electrical continuity)
- A wire soldered to the foil strip and the volume pot
Now she’s dead silent - no buzz when I take my hands off the metal parts.
I was quite surprised since only the floors and walls of the pickup cavities are shielded - they are 'open sky' so to speak...
I thought you’d find that interesting!
So you were right - on rear routed instruments, graphite painting the pickup cavities really helps.
Jay Menon
Postby Wonks » Tue Sep 25, 2018 3:18 pm
I suppose you can think of them as a Faraday cage with a hole in. The effectiveness of a Faraday cage (note the word cage rather than solid enclosure) comes down to the largest sized hole it it, which corresponds roughly to the shortest wavelength it will stop entering. So a hole that size will be good for most radio waves down to the start of microwaves.
Postby Jay Menon » Tue Sep 25, 2018 3:24 pm
Wonky - you're even more geeky than me :bouncy:
Jay Menon
Postby Wonks » Tue Sep 25, 2018 3:36 pm
I did do physics at Uni. But I did have to improve my basic knowledge on the subject of Faraday cages fairly recently by searching the web.
