Ok, it's not a guitar...
Postby blinddrew » Sun Feb 24, 2019 11:46 pm
But it is a very interesting fretted instrument (not a banjo):
https://www.youtube.com/watch?v=48RVcbk ... e=youtu.be
Re: Ok, it's not a guitar...
Postby Hewesy » Mon Feb 25, 2019 8:16 pm
Yikes - though a lovely tone to it...
Hewesy
Hewesy
Postby Folderol » Mon Feb 25, 2019 8:25 pm
Fascinating :clap: :thumbup:
Postby Sam Spoons » Mon Feb 25, 2019 8:51 pm
A good mate is a classical guitarist (and teacher and composer) and, for a good while he owned and played IIRC Renascence Lute. I can see why the Theorbo came into existence, the Lute is a very quiet, subtle instrument suited to drawing rooms not theatres.
Postby Jumpeyspyder » Mon Feb 25, 2019 10:13 pm
Very cool :)
Jumpeyspyder
Postby Nathan-VST-Plugins » Tue Feb 26, 2019 12:20 am
What a contraption... it sounds good. :thumbup:
Nathan-VST-Plugins
"I used to think I was indecisive, but now I'm not too sure."
Checkout my blog: VST Plugins Free Download
Postby Agharta » Tue Feb 26, 2019 9:01 am
It's a shame it's not 13 string as that's one more than 12.
14 is just pure extravagance, showing off.
Agharta
Postby Johnsy » Tue Feb 26, 2019 12:04 pm
I'm imagining an electric one.
Johnsy
Postby alanj84 » Mon Mar 25, 2019 1:41 am
I've actually seen this one before. Honestly that thing probably has 50 strings or so and you will use 6-7 max anyway.
alanj84
Postby awjoe » Mon Mar 25, 2019 2:36 pm
Thirteen thousand dollars. Ouch. But so-o-o-o-o lovely. Imagine changing strings on it? There goes a hundred bucks. Or two.
He said the cylinder that the strings wrap around when the instrument is folded keeps everything in tune. It might be true, but it's counterintuitive to what passes for my brain. If it works the way he says, it's very clever.
awjoe
Postby Wonks » Mon Mar 25, 2019 3:28 pm
awjoe wrote:He said the cylinder that the strings wrap around when the instrument is folded keeps everything in tune. It might be true, but it's counterintuitive to what passes for my brain. If it works the way he says, it's very clever.
The cylinder doesn't directly keep it in tune. It keeps the strings under reasonable tension so that the windings don't loosen at the tuners, so there's far less chance of the strings slipping and the tuning drifting. Also keeps the strings from slipping out of the nut slots etc. You'll probably get about as much tension variation with it as operating a standard Strat trem, so providing the slots are smooth, it should stay pretty much in tune, but you may still have the odd occasion where some small adjustment is necessary.
Postby The Bunk » Mon Mar 25, 2019 7:19 pm
Wow! Lovely. Do you reckon I could get one from Anderton's?
The Bunk
2 answers; 799 questions and about 58 "Mornington Crescent" posts.
