Balancing Speaker Cab levels
Re: Balancing Speaker Cab levels
Postby Sam Spoons » Wed May 08, 2019 9:19 am
Wot Dave sez, but to add I have never seen an electric guitar cab with a crossover (or a tweeter BTW) but mixing speaker sizes, while not common, is far from unheard of.
Postby ef37a » Wed May 08, 2019 9:35 am
Sam Spoons wrote:Wot Dave sez, but to add I have never seen an electric guitar cab with a crossover (or a tweeter BTW) but mixing speaker sizes, while not common, is far from unheard of.
"Hartke" bass cab Sam had a central tweeter but I remember thinking at the time....
WTF??!!
Postby BigRedX » Wed May 08, 2019 9:41 am
Mixing speaker cone sizes without using a crossover between might not be uncommon, but it is not good practice and more importantly for the OP will not give consistent results for all listening positions.
I'm assuming this is for a live rig, and the OP is obviously interested in getting the right sound. However by mixing cab designs and speaker cone sizes he will not be giving his audience the same sonic experience. Once he has sorted out the imbalance with the 2 x10 option of the rig he might well have the perfect sound where he is stood on stage, but very few of the audience will hear what he is hearing, and surely it is just as important that the audience get the right sound too?
Also if the PA is in anyway important at getting that guitar sound FoH then each different sized speaker will need to be mic'd up. If you are playing large arenas in a big name band, then it will probably happen. For the average <500 capacity venue, you'll get one mic on the "best" sounding or most conveniently located cab and that will be that.
BigRedX
RockinRollin' VampireMan
Postby Sam Spoons » Wed May 08, 2019 9:47 am
Yes, mostly true but I have never seen a guitar speaker with a crossover. The differences in frequency response between 10", 12" and 15" guitar speakers are relatively small with a huge overlap so all a crossover would do is remove and top end from the 15" and any low end from the 10"s which would be pretty much self defeating.
WTF??!!
Yeah, quite common in bass cabs (definitely a plus for slap bass styles), My Ashdown 2 x 10 and #2 son's Warwick combo both have tweeters, as do most acoustic guitar amps. Still never seen one in an electric guitar cab though.
Postby ef37a » Wed May 08, 2019 9:55 am
I see Sam, I agree, no tweeter for a sixer cab,
But a crossover for the tens? At what frequency? They are probably ok for 70Hz and up and a crossover at say 100Hz is going to need some big mother inductors and the non-polarized caps won't be cheap.
A crossover also, of itself does nothing to balance levels. In a perfect world both speaker would be 3dB(?) down at Xover f and then the response levels out again. Yes some crossovers have tweeter attenuating resistors but they will be picked for a specific set of drivers.
Postby Sam Spoons » Wed May 08, 2019 10:45 am
Plus the 15" frequency response extends up to 4kHz so rolling that off at 100Hz loses 4 or 5 octaves from it which will completely change the sound of the cab which the OP doesn't want.
Postby BigRedX » Wed May 08, 2019 11:46 am
ef37a wrote:"Hartke" bass cab Sam had a central tweeter but I remember thinking at the time....
WTF??!!
Nearly all bass cabs that aren't old school designs will have a tweeter, crossover and a volume control for the tweeter on the back panel.
Bass cabs that mix driver sizes will also have built-in crossovers and usually a level control for each of the smaller drivers.
BigRedX
Postby Sam Spoons » Wed May 08, 2019 12:19 pm
Yup, but not guitar cabs.
Postby ef37a » Wed May 08, 2019 12:20 pm
Sam Spoons wrote:Yup, but not guitar cabs.
And the OP has already said he does not want a pot!
Postby BigRedX » Wed May 08, 2019 1:17 pm
But ef37a was talking about a Hartke bass cab.
BigRedX
Postby Sam Spoons » Wed May 08, 2019 2:06 pm
True but that was why I qualified in my reply. The OP OTOH is definitely talking guitar cab. I do agree with many of your points, particularly that a couple of matching cabs would probably be a good option but the OP obviously likes the mix of timbres his complex setup produces.
Postby ef37a » Wed May 08, 2019 5:39 pm
Yes, I did and it put pussy among the pigeons. I won't go into why. Totally my fault.
We are only talking guitar cabs from now on. NONE of which ever had tweeters AFAIK!
Postby blinddrew » Wed May 08, 2019 9:51 pm
Well, some acoustic guitar cabs do...
::: ducks and runs for cover :::
Postby Sam Spoons » Wed May 08, 2019 11:58 pm
blinddrew wrote:Well, some acoustic guitar cabs do...
Complex thread but the OP is asking about electric guitar cabs powered by valve amps so 'normal' practice for bass or acoustic guitar amps is not really relevant. Your coat is on the hook by the door BD :smirk: .........
Postby zenguitar » Thu May 09, 2019 12:31 am
I think we are all missing the obvious here.
First, if the OP had found a cab combination that worked for him; he wouldn't be here asking the question. It, self evidently, doesn't work. What we can be certain of is that a combination of 1x15, 2x10, & 4x12 isn't delivering the goods. In my opinion, the previous advice of finding the one cab that works best and (if you need to be louder) buy another one the same, is the sensible route. Occam's razor and all that.
Second, we've not heard from the OP for a few days, but we appear to have sent him on a search for attenuators and cross-overs. Yes, it is possible to engineer a solution along those lines, but just because it's possible it doesn't mean that it is a good engineering solution.
Seven drivers of 3 sizes in three different size and volume cabs, and all producing overlapping frequencies. By any measure, that is a recipe for disaster.
If the OP returns I think we should be asking him "why are you doing this", "what are you trying to achieve". That way, at least, we might be of some assistance.
liberté, frivolité et vanité
