PC sound in signal path
Re: PC sound in signal path
Postby Martin Walker » Thu Aug 22, 2019 12:15 pm
Leftyjay wrote:Ill check the socket and identify the culprit but in the meantime, ill just buy an extension to connect the pc at the other end of room (room is pretty large)
The trouble with this approach is that you won't have broken the ground loop, but simply changed its size. Often this makes the offending noises worse, which is why others in this thread have already suggested plugging in all your gear to a single mains socket via one or more distribution boards.
This won't ''break' the ground loop either, but in most cases making the loop physically smaller results in lower amounts of noise, because the currents are lower.
A case in point - my own small studio is powered via a single mains wall socket, and the only time I've had ground loop noises is when I powered a master keyboard via a mains socket on the other side of the room. As soon as I moved the keyboards's power supply so it could be plugged in with all my other gear, that noise disappeared, and has never come back.
Good luck whatever you decide to do though ;)
Postby Leftyjay » Thu Aug 22, 2019 3:22 pm
Initially, it WAS already in the same socket. The problem is worst when pluging in the same powerbar. It gets 90% down in noise if the PC is plugged (not moved) to another electrical socket.
Leftyjay
Postby blinddrew » Thu Aug 22, 2019 3:34 pm
Leftyjay wrote:Initially, it WAS already in the same socket. The problem is worst when pluging in the same powerbar. It gets 90% down in noise if the PC is plugged (not moved) to another electrical socket.
Odd, but if it works... :thumbup:
Postby Hugh Robjohns » Thu Aug 22, 2019 3:57 pm
Ground loops can and often do very strange things and behave in strange ways. It's all to do with the routes the earth current noise flows. Sometimes -- as here -- doing what should be the wrong thing can appear to improve the situation. However, it's not really a cure, it's just that some of the circulating noise currents have partially cancelled each other out. It's actually an indication that there is more than one ground loop affecting the system as a whole!
Postby Martin Walker » Thu Aug 22, 2019 8:18 pm
Hugh Robjohns wrote:Ground loops can and often do very strange things and behave in strange ways. It's all to do with the routes the earth current noise flows. Sometimes -- as here -- doing what should be the wrong thing can appear to improve the situation. However, it's not really a cure, it's just that some of the circulating noise currents have partially cancelled each other out. It's actually an indication that there is more than one ground loop affecting the system as a whole!
That's exactly the point I was trying to make Hugh :headbang:
Postby Leftyjay » Fri Aug 23, 2019 11:50 pm
Good news is that the noises are at an acceptable level. Still there, but barely audible so im good...for now :P
Leftyjay
