Revitalising Arkieboy's 1979 Gibson "The SG"
Page 1 of 3
PostPosted: Fri Sep 06, 2019 12:23 pm
by Wonks
As it’s quite an interesting guitar, I thought I’d describe working on Arkieboy’s (Steve Harris) 1979 Gibson “The SG”, bringing it up to a state where his son, Matthew, can take it off to University with him instead of his 2017 Firebird. This set out as a simple set-up and electronics upgrade, but it threw a few curveballs along the way that made it quite challenging. As such I didn’t take as many photos as I should have done, especially of the initial state of the guitar. But hopefully you’ll get an idea of what went on.
The Gibson “The SG” followed on in 1979 from 1978’s “The Paul”. These were both lower cost ‘entry-level’ versions of the SG and Les Paul, featuring natural walnut bodies and three-piece walnut necks, ebony fingerboards and a clear satin finish. Both had Grover ‘milk bottle’ tuners with metal tulip buttons. The next year, 1980, the “The SG” transformed into the SG "Firebrand” (as did “The Paul” become a Firebrand), with a branded/burnt-on Gibson logo on the headstock instead of the gold Gibson transfer that this has. There was also some patchy light scorching on the body of the Firebrands.
Headstock detail showing the gold Gibson decal. Very hard to read against the walnut background at most angles. What were Gibson thinking? Obviously saving money by not having to veneer and paint the headstock face black:
Despite being advertised as coming with a more powerful bridge pickup, the perceived web knowledge seems to indicate that most of “The SG” models came out of the factory with the standard “T-top” humbuckers of the period. The neck pickup is generally deemed fine, but the bridge pickup was always perceived as weak sounding. It probably didn’t help that this was the period when Gibson were fitting 300k volume and 100k tone pots to LPs and SGs, instead of 500k pots for both positions as previously and currently used.
Arkieboy describes getting the guitar:
I spotted this one in the second-hand section in Musical Exchanges in Birmingham and bought it because I wasn’t getting on with a (second hand) Ibanez Alan Holdsworth (wish I still had that one). I installed a GK2 and it became my main guitar for the Ark album ’Spiritual Physics’ and the extensive touring we did in a dilapidated converted 50 seat Bedford coach. Right at the height of the controversy with New Age Travellers.
The guitar was loaned to the son of a very good friend of mine for about five years, who learned to play guitar on it on the basis that it would have a re-fret some time during the loan. The original frets were much more traditional Gibson fret wire AFAIR
The SG as it came to me:
The new frets were much wider and higher than the original Gibson frets, they were also stainless steel (something I didn’t find out about until later). But even so, there was still some light fret wear on the first few frets. The neck isn’t the normal thin SG, style. In fact, it’s pretty solid and chunky with substantial shoulders to it, making it more of a D than a C profile. No detuning by shaking the neck around on this guitar.
The headstock is the very-wide, almost spade-like, headstock of that era. At 91.7mm across the tips. My 1998 Les Paul JP model has the narrowest tip-width of my Gibsons at 76.5mm, which is just narrower than the 77mm of my 1965 Country Western. My 2018 Les Paul Goldtop's headstock is somewhere in the middle at 81.3mm (which I presume went wider because of the need for more space when they started fitting robot tuners).
So overall the '79 SG's headstock is around 15.2mm wider than the ‘50s/’60s headstocks. Presumably Gibson went the bigger headstock route because Fender did.
The original Grover "milk bottle" tuners, so-called because of their shape where they narrow towards the button:
Sometime in the mid/late ‘80s, Arkieboy fitted a Jaydee ‘Hooligan’ pickup in the bridge position (as he too thought the bridge pickup was weak sounding). His band’s bass player worked at Jaydee, so got him the pickup. You may have guessed from the name that this is a high output pickup. I measured the pickup DCR at 24k, but I have no idea of the wire gauge used. The pickup has a black plastic cover and a PCB style base:
There were some marks on the body where there was a Roland GK2 MIDI pickup installed, including a couple of screw holes near the bridge.
Otherwise, apart from Schaller straplocks, the guitar was stock, if rather worn. There was a year when Arkieboy was playing three gigs a week with it. And Arkieboy is one of those players who sweats a lot, plus his sweat is pretty corrosive. There weren’t many areas that his sweat hadn’t reached, so there were corroded screws, corroded pots, and probably most impressive, a very corroded bridge! There's relic level and then there's this. Several previously unknown lifeforms were discovered living in the grunge:
You can also see on the last picture how the strings have eaten away into the metal at the back of the bridge as a result of having the tailpiece set too low. This is not a good thing and the strings should never be allowed to touch the rear of this type of bridge.
One of the pickup rings was missing a corner, the other had a fixing screw missing that had rusted through and broken off at body level.
So there was a fair amount to repair. The plan was to replace all the pickup rings, the pots, the selector switch and the (barrel type) output jack and make a new harness. The Jaydee bridge pickup was a bit too much of a battering ram for Matthew’s purposes, so after some discussion. Arkieboy settled on an Iron Gear Dirty Torque (a SD JB style pickup).
We did talk about maybe fitting some extra switching options, but we didn’t want to drill extra holes in the guitar and the shallow body of the SG precluded fitting switching pots. The control cavity is only 24mm deep, and unfortunately the shallowest switching pot out there is just over 25mm.
Arkieboy ordered up all the new bits and then delivered the guitar to me along with the parts.
The first step was to strip all the parts off the guitar. I started with the tuners and found the anti-rotation screws were all loose in their holes, so they got filled with cocktail sticks for later re-drilling.
Here you can see the headstock is clearly made up from the three pieces of neck walnut, plus two more for the wings. And you can see the widened screw holes, presumably from the tuners being knocked about a fair bit:
Then off with the bridge and tailpiece. The original bridge, a Nashville type, was being replaced with a locking TonePros unit. The existing tailpiece was being reused after a good clean and polish.
The tailpiece bushes remained in place, but one of the bridge body bushings simply came out when I pulled on the height adjustment post, so I decided to use the new bushings that came with the TonePros bridge and so pulled the other existing bushing out as well.
Then out came the electric bits. The barrel jack was quite hard to remove as the locking nut had rusted up, and was also pulled into the body, so there was very little of the nut available to get a spanner on. WD40 to the rescue!
The original control cavity wiring:
I hit a snag when it came to the scratchplate, as two of the screws were so sweat corroded and rusty that a screwdriver couldn't get a grip to turn them at all. So, it was 'drill the heads off' time. This got the scratchplate off but left two screw studs protruding. One came out when turned with pliers, but the other was so rusty that it broke off at body level when I set the pliers on it. That left a total of two screw holes with broken studs left in them to deal with.
This picture shows (A) the rusted pickguard screws before removal, (B) the broken off pickup-ring screw, (C) a GK2 pickup screw hole after filling but before colouring and (D), lighter areas where the GK2 controller used to sit. You can also see areas around the pot shaft holes where the rusty washers left marks on the lacquer:
There was a spilt in the wood around a control cavity cover plate screw hole, so I glued that back together:
With all the old parts off the body, it was time to give it a clean and an initial polish. The back of the neck was very rough, partly through ridges where the three pieces of neck were glued together, and partly through accumulated dirt and old skin stuck to it. So, the neck was sanded until the dirt and ridges were off, but there was still finish on the neck, and then polished up with increasingly fine grades of Micromesh until it was smooth feeling. The back of the neck still has a couple of slight dents in it, but you can’t fell them when playing.
The body then got a clean with soapy water followed by a rub over with some T-Cut to restore some shine to the finish. It’s a 40-year old guitar that had been heavily used, so has a fair amount of wear and tear on the finish. It was never going to come up like a brand-new shiny guitar, but it took the dull edge off it and added a semi-gloss look to it.
The hardware also got a good clean and polish to get the worst of the tarnish off it. Here are before and after pictures of the T-top pickup after a good clean. You can clearly see the 'T' embossed into the top of each coil, designed to help the less-skilled workers Gibson now employed to orientate the two coils in the correct direction:
I filled the two old GK2 screw holes with filler, coloured it with my secret colouring technique, then put a couple of coats of clear over the top of those areas for protection.
My next step was to work on the frets. There were those wear marks and investigation had showed that there were a few slightly high frets that prevented setting a decent action. The neck was first straightened using the truss rod and a notched straight edge. It wasn’t the flattest fingerboard that I’d ever seen and I couldn't get rid of all the small gaps under the notched edge, so I just got it as flat as I could.
The tops of the frets were then marked with a black Sharpie and the fret file run along the frets until the black marks had all gone from the very top of the frets, plus until all the dents on the lower frets were gone.
The frets were then re-profiled and polished. Re-profiling and polishing took a very long time, and it was only then that I suspected that the frets were stainless steel and not standard ones. The fact that the frets were pretty shiny when the rest of the guitar was so dull should have alerted me. I really hate working on stainless steel frets because they take so long to do!
The ebony board was then cleaned and lemon oiled. Non-figured ebony is so dark that it doesn’t look dry, but the board soaked up three generous applications of oil. The board had been chipped in a few places when the replacement frets were installed, but all the chips were right near the fret slots, so you couldn't feel the indents, and so not worth trying to fill with black superglue.
The control cavity and underside of the control cover were then copper foil screened:
I now had to deal with those two broken screws – something new for me. I had a look around on Amazon for something that could help me to drill them out and came across drill bits for drilling cabinet hinge screw holes, with a retractable outer metal sheath that held the drill central in the hinge holes. This endures that the pilot holes are all properly centred, and you don’t get Wonky® hinges.
So I made a two quick MDF templates up, marking on the position of the screw holes near to the errant screw stubs plus the stub position on paper, then sticking that on the MDF:
I then drilled holes for locating screws and a larger hole that the centralising drill bit would fit into snugly, and screwed the template on and using a drill stand to keep things as vertical as possible, drilled out the two stubs:
I amazed myself as it worked almost perfectly, with just the merest sliver of old screw remaining that I prized out with a scalpel blade in each case. You can just see the screw slivers in this picture:
The holes were then plugged ready for re-drilling. All the pickup ring mounting holes were on the wide side and the mounting screws not grabbing tightly, so they all got plugged as well.
Then it was time to do the wiring. A cardboard template was first made up with holes for the pots and selector switch on, in order to wire the basic components together outside the body.
I pre-wired the barrel jack and to make it easier to fix back in the body, I fitted a large washer over the barrel that I had filed most of one edge off, as the jack was located very close to the bottom of the control cavity (when looking down from the rear) and a full sized-washer wouldn’t fit. This stopped the locking nut from pulling itself into the wood when tightened. The wiring harness then went in.
It was then time to fit the pickups, so I first went to fit the mounting rings and discovered that the pickup rings supplied were longer than the originals (92mm vs 89mm). As the pickguard abutted the rings, it wasn’t just a case of drilling new mounting holes, it was a case of finding some original sized pickup rings otherwise the pickups themselves would be offset from centre.
And this was where I found that most replacement pickup rings sold are 92mm and not 89mm. Of course, Gibson do sell pickup rings, but a web search didn’t show up any angled, black, flat-bottomed pickup ring sets. I found a neck one, but not a suitable matching higher bridge one. So, it was back to a detailed search of parts supplier sites. Northwest Guitars had both 89mm and 92mm rings available, so I ordered a set of the 89mm ones. Except that when they came, they were 92mm ones in 89mm labelled bags. It took over a week to sort out that their supplier had changed things without telling them, so they no longer supply 89mm rings.
Original 89mm ring vs new 92mm ring:
So I eventually tracked some down at Allparts, and they arrived and luckily turned out to be a perfect match. So they were fitted, then the pickups (original T-top neck, Iron Gear Dirty Torque bridge) got fitted and wired. The tuners got re-fitted and the anti-rotation screws hole re-drilled. It was useful to find out that the tuners also had three protruding ridges on the underside that also acted as anti-rotation devices, so it was easy to put them back on in exactly the same position as they came off.
The strings got put on and I began to set up the guitar. I struggled here, and although I could get a playable action, it wasn’t a great action, with the bottom E being the string that buzzed the most if I tried to lower it. It was better than when it came, especially as I’d lowered the nut slots which were quite high. But it was not a lot better.
And I’d also discovered that the Iron Gear pickup was reverse phase to the Gibson pickup, so the mid-position was out-of-phase. A nice sound to be told, but not as useable as the normal combination, so I had to swap the ground and signal wires on the Iron Gear. (I also found this situation when I installed one Iron Gear P90 in a guitar with an old SD P90 in, so maybe that’s the case for all their pickups). Luckily the Dirty Torque has 4-conductor wiring (unlike the T-top), so it was an easy job to swap the wires around.
The Dirty Torque had a very new and shiny look to it, so I toned that down to be more like the T-top by rubbing the bobbin top and screws with 6000 grit Mircomesh, just to take the edge off the shine.
As I have a 12” radius block, I decided to have another go on the frets using that. So, I stuck some P240 grit wet and dry paper to it. Then I pulled it off and stuck the paper to it the right way up this time (d’oh!). Black marker on the fret tops, a quick scrape, and it was immediately obvious that the frets hadn’t been properly radiused to match the board when originally fitted as I was taking a lot off the edges and nothing in the middle. After about an hour (stainless steel frets, grrr!), I had them the proper radius and definitely all relatively level. It really does help when setting up for a low action that the fret radius matches the bridge saddle radius, especially when you have non-height adjustable saddles as on a tune-o-matic bridge (both ABR and Nashville versions).
Now it was time to re-profile the frets again. I have diamond profiling fret files but even these took ages to get the right profile on each fret. (I probably need to get some replacements). It didn’t help that the fret edges had so much off that the edges were almost rectangular and took a lot of filing to get them rounded, with no black marker showing along the top of each one.
In desperation, after doing just 12 frets in a day, I bought a cheap £7 (made from) stainless steel fret profiling file from Amazon. It worked remarkably well. The results were a little bit rough, but I had the diamond files to smooth things off. Then another polishing session followed, after which I was ready to try again with a set-up. A half-turn clockwise on the truss rod from the flat neck position (my go-to initial setting which normally works well) and I was ready to string up again.
The strings went on, the bridge height came down and – perfect! Low, choke-free action:
A bit more polishing of the body and it was finished:
The neck pickup has a nice well-defined sound to it. The Dirty Torque is a bit too mid-rich and powerful for my tastes, but it should hopefully suit Matthew's. He definitely wanted something with more poke and less treble than his Firebird pickups. But if not, a new pickup is only a soldering iron away.
Arkieboy comes to pick up the guitar tomorrow (Sat 7th Sept 2019) after a few postponed dates, but I think he'll be pleased with it.
Re: Revitalising Arkieboy's 1979 Gibson "The SG"
PostPosted: Fri Sep 06, 2019 1:04 pm
by arkieboy
I promise to look after my guitars and clean them regularly.
PostPosted: Fri Sep 06, 2019 3:04 pm
Another superb job Wonky, envious of your skill and patience. :clap:
PostPosted: Fri Sep 06, 2019 3:31 pm
Nice write up too. Had me gripped to the end and I don't know niffinck about geetars... :-)
Tell me more about that special hinge drill bit...
PostPosted: Fri Sep 06, 2019 4:01 pm
by Wonks
Hugh Robjohns wrote:Tell me more about that special hinge drill bit...
It's not rocket science. The drills basically look like this:
The end sheath is spring loaded, so as you drill, pushes back like this:
It doesn't push back that far, maybe 1cm, but its enough to get a hole started, which is normally all you need. The outer sheath screws off, so you can use the full length of the drill for a deeper pilot hole if you want. You get a set of them, so you just have to pick the one that most closely matches the holes in the hinge. Stick the end of the sheath in the hole and then the drill hole is always central. Of course you've still got to put the hinge in the right pace first!
This is the set I bought: https://www.amazon.co.uk/gp/product/B01 ... UTF8&psc=1
The drill bits are held in place with a grub screw, so you can replace the drill bit itself if necessary.
PostPosted: Fri Sep 06, 2019 4:05 pm
Excellent. Very simple but elegant idea. never seen those before. Thanks.
PostPosted: Fri Sep 06, 2019 4:32 pm
by ManFromGlass
I just love reading stuff like this.
:thumbup: :thumbup:
PostPosted: Fri Sep 06, 2019 4:44 pm
by Eddy Deegan
Very interesting. An excellent writeup and some jolly good handiwork there Wonks, thank you for sharing! :clap:
PostPosted: Fri Sep 06, 2019 4:50 pm
by Folderol
Seriously impressed - yet again!
Oh, and I love those drill bits. Really neat idea :thumbup:
PostPosted: Fri Sep 06, 2019 5:57 pm
by adrian_k
Nice job and write up. And thanks for the hinge drill bit tip - very useful!
PostPosted: Fri Sep 06, 2019 6:53 pm
by Wonks
You might get away with just making a guide hole in some MDF, as long as you can keep it fixed in place. That was my first thought, but then I found those bits and modified the MDF idea instead.
PostPosted: Fri Sep 06, 2019 7:08 pm
by CS70
In awe as always, Wonks - read it like a I would a novel :)
PostPosted: Fri Sep 06, 2019 7:28 pm
by Martin Walker
Yes indeed - most impressive transformation despite various difficulties :clap:
Like Hugh, I'm not really a guitar person, but even so I learned a lot from Wonks' write-up that I'm sure will benefit me in the future with my wooden steampunk creations :thumbup:
PostPosted: Fri Sep 06, 2019 9:13 pm
by Watchmaker
Nice work Wonks. Screwing the MDF template down for the pilot holes was a master stroke and the guitar looks gorgeous! Is that Pb free solder?
I'm exceedingly impressed by the photo documentary and tempted to post a few meagre pics from a build I did a few years ago in homage to your inspiring write ups!
Do you do this for a living or just a masochist?
PostPosted: Fri Sep 06, 2019 9:38 pm
by Wonks
Just do it for pleasure. I like to unleash the hidden potential of guitars.
No, I used 60/40 solder for ease of use. I do have Pb-free solder for repairing modern stuff, but prefer the leaded stuff - especially as the pickup braid had leaded already on it, and lead and lead-free solder don't mix.
