Wireless system
Re: Wireless system
Postby Wonks » Tue Oct 08, 2019 2:31 pm
No it should be fine in that context - and it obviously is for you.
Re: Wireless system
Postby mick.n » Wed Oct 09, 2019 3:55 pm
[quote="Music Wolf
If you're going to use wireless this way then I suggest that you go the whole hog and wear leather pants (which look really good with your gut hanging over your belt).[/quote]
:bouncy: :D Haha, fortunately the expanding gut syndrome hasn't bestowed itself on myself & the rest of the band (thus far).
My rational for a wireless system is that I do a lot of switching between guitar & keyboards. Good chance of tripping over a guitar lead. Also, less chance of a 240 volt thrill if the venue has dodgy electrics.
I decided to go for the Line 6 system that Wonks mentioned. Thanks again for all the replies & info. :thumbup:
mick.n
Re: Wireless system
Postby ore_terra » Wed Oct 09, 2019 5:25 pm
I've owned that line6's little brother (G30) for a couple of years now. the only dropout I've had was due to the cable I was using.
I'm also one of those who likes to wander out into the audience :wave: and the 1st thing I do during sound/line check is to see how far I can move from the receptor (to avoid dropouts)
latency wise, I don't know the msecs but I can say that on IEM's I could play perfectly.
ore_terra
Re: Wireless system
Postby BigRedX » Thu Oct 10, 2019 8:54 am
Overall the Line6 wireless units are a good choice. However be aware that on some models at the cheaper end of the range there have been problems with the battery door on the transmitter unit. Check the reviews before you make a choice.
BigRedX
RockinRollin' VampireMan
Re: Wireless system
Postby ore_terra » Thu Oct 10, 2019 10:28 am
BigRedX wrote:Overall the Line6 wireless units are a good choice. However be aware that on some models at the cheaper end of the range there have been problems with the battery door on the transmitter unit. Check the reviews before you make a choice.
yes, G30 like mine show that issue commonly (not to me, fortunately). people is moving to the G10 instead that does not need a battery.
ore_terra
Re: Wireless system
Postby mick.n » Mon Oct 14, 2019 9:39 pm
Delivered today at noon........at 6 pm i gave up on trying to get this thing up & running. Will not pair with the transmitter most of the time & when it does (After 50 seconds of turning the transmitter on) it makes a high pitched screeching noise.
Have yet to be able to get any sound on the odd occasion when it does connect.
Looks like a return. :headbang:
mick.n
Re: Wireless system
Postby shufflebeat » Mon Oct 14, 2019 11:21 pm
Which one?
shufflebeat
Re: Wireless system
Postby mick.n » Tue Oct 15, 2019 10:11 am
shufflebeat wrote:Which one?
Sorry,. :headbang: the line 6 G75.
mick.n
Re: Wireless system
Postby Wonks » Tue Oct 15, 2019 10:30 am
That's a shame.
Re: Wireless system
Postby Sam Spoons » Tue Oct 15, 2019 10:44 am
Clearly a faulty unit, will you ask for an exchange unit or a refund?
Re: Wireless system
Postby mick.n » Tue Oct 15, 2019 11:04 am
Sam Spoons wrote:Clearly a faulty unit, will you ask for an exchange unit or a refund?
It's getting swapped out on Thursday Sam. I'll have another go with this model. :)
mick.n
Re: Wireless system
Postby Wonks » Tue Oct 15, 2019 11:13 am
Did you ask Andertons to test the replacement before sending it out? I've done that with a faulty FX pedal and they did.
Re: Wireless system
Postby Sam Spoons » Tue Oct 15, 2019 11:38 am
Sounds like a plan :thumbup:
Re: Wireless system
Postby mick.n » Tue Oct 15, 2019 2:36 pm
That's a good idea Wonks....... I'll give them a ring. :thumbup:
mick.n
Re: Wireless system
Postby BigRedX » Wed Oct 16, 2019 5:44 pm
Also be aware that the Line6 G75 unit failed a German broadcast compliance test and supposed to be in the process of being updated to conform. However a year on and there is no sign of updated units or any information about what is going to happen to all the non-compliant ones already out there. This might be the reason why they are such "good value" in the UK at the moment...
BigRedX
