Bias FX with external IR loader?
PostPosted: Sat Oct 19, 2019 12:10 pm
by Demious
I want to use an external IR loader with Bias FX2, but I cant find how to set this up.
At the bottom is an option to turn off the speaker function, but when I put an IR loader after FX2 in the channel, within Bias both amp lines are summed together and send as a single signal into the IR plugin. So Im going to need 2 IR loaders, each connected to one amp, but I cant find how to get each seperate signal out of FX2 and send it to their respective speaker. How do I setup FX2 so I can connect each amp to its corresponding speaker?
