Tell me about Expression pedals...
Re: Tell me about Expression pedals...
Postby ManFromGlass » Wed Oct 30, 2019 6:53 pm
Wonks :thumbup:
Today’s groan award!
Postby Luke W » Wed Oct 30, 2019 8:39 pm
Studio Support Gnome wrote:Zoom also made the most insane expression pedal of all time , on my old MultiFX unit (the G9.2tt which I still have ) , the large pedal on the right hand side could have it's top surface "unlocked" from the supporting structure... and move laterally through about 30 degrees, giving you both vertical travel and lateral travel so you could control two discrete effect parameters , from one pedal, at the same time...
Not as cool movement wise, but the Source Audio Reflex has multiple outputs as well as a MIDI out to control multiple devices. You can assign different tapers to different outputs, even send out an LFO and control the speed with the pedal, ultimate silly noise machine.
I picked one up second hand but haven't finished putting my rig together yet so haven't had a chance to have a proper play.
Luke W
Techie / Musician Of Sorts
