Bought myself a Christmas present!
Postby garrettendi » Fri Dec 13, 2019 9:52 am
A used Marshall GV-2 pedal... Used to have one when I first started but I got frustrated that it "didn't sound good". Now I know the problem was me not the pedal...
It needs a bit of work, the mid knob isn't starting and stopping at the same point as the other knobs but should be an easy fix.
I plan to plug this into my interface and then feed it into the Ignite Amps TPA-1 VST power amp sim and some impulse responses and try and get a decent JCM800 sound.
Anyone hazard a guess as to whether that idea will work?
garrettendi
Re: Bought myself a Christmas present!
Postby Wonks » Fri Dec 13, 2019 10:49 am
Either it will, or it won't.
It's not a JCM800, it's a fairly cheap pedal that distorts in similar way to a JCM800, so don't expect it to sound exactly like a JCM800 clone.
Some web searching shows the pots to be mounted on their own PCB, rather than chassis mounted, so if it's a damaged pot, it may be harder to repair than you think. Although it may be that it's just the knob that needs adjusting on the spindle.
Now wrap it up, put it away and don't play with it until 25th Dec.
Postby garrettendi » Fri Dec 13, 2019 11:17 am
I can't remember if I gave the mid knob a proper run through in the shop, but it sounded good.
Bit concerned I may have wasted the cash now :(
garrettendi
Postby Wonks » Fri Dec 13, 2019 11:22 am
Just try it out. Don't worry until you've heard it in anger.
Postby ef37a » Fri Dec 13, 2019 12:15 pm
They are reckoned G to be about as close to a good Marshall sound as you can get with a pedal (see thefretboard.co.uk) into a fairly clean amp.
Dual concentric pots can be a bit of a PITA to find as spares and something of a trial to change. Best way I found was to flood all the pins with solder then a quick BANG! Upside down on a bench. Watch for flying hot solder! But you might get away with a spray of cleaner, at least for a month or three.
Bad buy? You could not buy the case and switches for that as spares.
Postby garrettendi » Fri Dec 13, 2019 12:23 pm
Thanks Dave, I feel a bit better now about my purchase. The pedal sounds absolutely amazing into a clean Fender amp so even if the mid knob needs repair it is still decidedly usable!
A mate of mine is an Electrical Engineer who might fix it for me for the price of a pint, so I'll give him a buzz at some point.
At least I know the purchase wasn't a waste.
garrettendi
Postby IAA » Fri Dec 13, 2019 12:27 pm
It's all about the sound! If it inspires its more than repaid the outlay, waiting for some tunes in the new year!
IAA
Postby garrettendi » Fri Dec 13, 2019 12:30 pm
Oh believe me, when I was in the shop I was VERY inspired, even though the test guitar I used was awful!
garrettendi
Postby gingertimmins » Fri Dec 13, 2019 10:55 pm
It’s a decent pedal. I have one and also the blues breaker overdrive. I upgraded mine for no other reason than I wanted a different flavour of drive on my board.
Between the pedal and the right amp sim you’ll be hard pressed to distinguish it from a jcm in a decent mix. Even isolated it will sound decent.
£35? Good purchase!
gingertimmins
Postby Martin Walker » Fri Dec 13, 2019 11:44 pm
ef37a wrote:Bad buy? You could not buy the case and switches for that as spares.
Quite true - that's a fine-looking piece of hardware with some convincing long-term wear to add to its personality.
Bargain!
Postby garrettendi » Fri Dec 13, 2019 11:46 pm
Thanks chaps for all the nice comments! I plan to hit the studio tomorrow so will update you all!
garrettendi
Postby Sam Spoons » Sat Dec 14, 2019 11:03 am
Another +1 for the build quality of those Marshall pedals I have about 3 in the spare stomper drawer inc a GV-2.
Postby Dynamic Mike » Sat Dec 14, 2019 12:13 pm
My Guv'nor doesn't look anything like that. I presume this is either an earlier incarnation or else a trendy retro reissue.
Dynamic Mike
Is it too late to cancel cancel culture?
Postby Hugh Robjohns » Sat Dec 14, 2019 12:24 pm
garrettendi wrote:It needs a bit of work, the mid knob isn't starting and stopping at the same point as the other knobs but should be an easy fix
If you mean the mechanical end stops of the knob are at different rotational angles to the other controls, then it's probably just a loose or slipped nut securing the pot shaft to the case -- assuming the pots are wired to the circuitry rather than mounted on a PCB. Check the construction inside the box.
But if its wired and loose or has slipped, remove the knobs, loosen the nut, reposition the pot, tighten, and refit knobs.
The knobs are probably secured to the pot shaft with recessed bolts in the side -- usually just one each, but some have two at 90degrees to each other. And they could be slotted grub screws or an Allen (hex) bolts.
When repositioning the pot, do check the internals to make sure you're not stressing the wires
Postby garrettendi » Sat Dec 14, 2019 12:40 pm
Hugh Robjohns wrote:If you mean the mechanical end stops of the knob are at different rotational angles to the other controls, then it's probably just a loose or slipped nut securing the pot shaft to the case -- assuming the pots are wired to the circuitry rather than mounted on a PCB. Check the construction inside the box.
That sounds easily done by my qualified friend!
Mike: I think it’s just been well used!
garrettendi
