Pedalboard Day!
Page 2 of 5
Re: Pedalboard Day!
PostPosted: Tue Jan 14, 2020 12:39 pm
by garrettendi
Kwackman wrote:That 500mA max load will soon get used up depending on what pedals are used.
Garrettendi- what pedals are you going to use?
Thanks!
Morley Bad Horsie
Boss TU-3 tuner
Joyo Ultimate Drive
Behringer HM-300
Marshall GV-2
Biyang Metal End King
I was actually planning on taking the entire board to a guitar shop and getting them to advise and wire up the power supply
Re: Pedalboard Day!
PostPosted: Tue Jan 14, 2020 12:45 pm
by Wonks
All basic analogue circuits apart from the TU-3, and that's only 30mA, So 500mA would be fine for the current set up (did you see what I did there?).
Re: Pedalboard Day!
PostPosted: Tue Jan 14, 2020 12:47 pm
by garrettendi
I couldn't find specs for the Metal End online but the Akai version (it's a clone) says to use a minimum 200mA power supply? But are you saying it's not a 200mA draw?
Re: Pedalboard Day!
PostPosted: Tue Jan 14, 2020 12:48 pm
by garrettendi
Found a picture of the back of the Metal End here: https://www.amazon.co.uk/ammoon-Distort ... NrPXRydWU=
Re: Pedalboard Day!
PostPosted: Tue Jan 14, 2020 12:49 pm
by The Elf
Hugh Robjohns wrote:Better to wait a while till the piggy bank is healthier than rush out and buy something that you'll need to replace very soon. And a decent PSU will last a lifetime, of course...
+1 :!:
Do you seriously want to be fastening/unfastening the pedals to muck about with batteries?! Wait a little longer and do the job properly.
But 200 quid?!?! Nah! The one I use typically goes for between 10 and 20 quid on eBay.
Re: Pedalboard Day!
PostPosted: Tue Jan 14, 2020 12:50 pm
by Wonks
garrettendi wrote:I was actually planning on taking the entire board to a guitar shop and getting them to advise and wire up the power supply
And I thought you were trying to save money! It really is a no-brainer to plug the PSU cables into the pedals. All the voltage and polarity of the pedals will be 9v centre negative to the Boss standard.
Re: Pedalboard Day!
PostPosted: Tue Jan 14, 2020 12:52 pm
by Wonks
garrettendi wrote:I couldn't find specs for the Metal End online but the Akai version (it's a clone) says to use a minimum 200mA power supply? But are you saying it's not a 200mA draw?
It says 43mA further down the Amazon page.
Re: Pedalboard Day!
PostPosted: Tue Jan 14, 2020 12:58 pm
by The Elf
Absolutely no need! Just plug it all in and use it! Any advice you need is here on the forum.
Re: Pedalboard Day!
PostPosted: Tue Jan 14, 2020 1:00 pm
by garrettendi
The Elf wrote:Absolutely no need! Just plug it all in and use it!
Think I might do that then... What's the danger if something goes wrong?
Thanks to everyone for your help, and I apologise for being so tight with the pennies.
EDIT: I mean I'll get the Thomann one.
Re: Pedalboard Day!
PostPosted: Tue Jan 14, 2020 1:03 pm
by Wonks
Just check the supplied leads before you use them and don't use ones with reversed voltage polarity connections (normally have a red end) and you'll be fine.
Re: Pedalboard Day!
PostPosted: Tue Jan 14, 2020 1:07 pm
by Luke W
garrettendi wrote:Think I might do that then... What's the danger if something goes wrong?
There's not too much that can go wrong really, if the pedals are all expecting 9V and you have a PSU with a load of 9V outputs then you're pretty much in the clear. As Elf says, if in doubt just ask here.
Re: Pedalboard Day!
PostPosted: Tue Jan 14, 2020 1:14 pm
by Watchmaker
Another bit...the 500mA rating is max draw...do you ever have a situation in which all your pedals are in use at the same time?
I have anywhere from 6 to 10 pedals in my board and it's rare that more than 4 are on at once so the max rating never really comes into play.
Also, fwiw I use a voodoo power 2 which allows me to alter voltage for two outputs and provides leads for non standard pedals. about $170 USD new, much less used.
Although lately I can hear it whine and I'll probably replace it soon, it has been through the wars for about 8 years now so I won't fault it for giving up the ghost.
Re: Pedalboard Day!
PostPosted: Tue Jan 14, 2020 1:17 pm
by garrettendi
Watchmaker wrote:Another bit...the 500mA rating is max draw...do you ever have a situation in which all your pedals are in use at the same time?
The most I'll have on at a singe moment is may two of the gain pedals and the wah. The TU-3 would also be switched on when tuning, so thats a max of 4 pedals at once and that's probably going to be a very rare occurrence.
What about the buffered pedals like the TU-3? Will they always draw?
Re: Pedalboard Day!
PostPosted: Tue Jan 14, 2020 1:37 pm
by Wonks
Yes, though I suspect most of the electronics will be active in the tuner all the time, you just won't be lighting any LEDs in bypass.
Re: Pedalboard Day!
PostPosted: Tue Jan 14, 2020 1:44 pm
by garrettendi
Wonks wrote:Yes, though I suspect most of the electronics will be active in the tuner all the time, you just won't be lighting any LEDs in bypass.
Ah! So from the sounds of that all will be well. Once payday hits, I'll get the Thomann one and plug in and test them one at a time.
Some of the reviews talk of a nasty hum... Does anyone know how bad that is? I'm not hugely fussed, and I can always upgrade later.
