SPST switch for old guitar
Postby Kwackman » Wed Jan 15, 2020 7:08 pm
Hi, I'm tidying up an old guitar I've had for many years.
It's a Vox VG6 from the 60s, a copy of a Gretch.
It's 335 shaped with single coil (but humbucker sized) pick-ups.
It has single volume and a single tone pot, and a rotary pick-up selector.
Then we have 3 toggle switches (all the same) which are, to me, oddities.
From the outside of the guitar, they look like a Les Paul PU selector switch, except with only 2 positions.
One is an on/off switch for the guitar's output.
The others are tone switches, using a capacitor, one for each pick up.
One of the switches is damaged beyond repair, and I'd like to replace it if I could find one.
Electrically, I think they are called SPST NC.
Each one only has 2 tags, and when the toggle is "straight" the tags are showing 0 ohms.
I can find similar switches, but they are heavy duty for mains with very definite "stiff" switching, I need the "Soft" feel of a Les Paul style switch. I hope that bit makes sense!
A mini toggle won't fit.
Anyone any ideas where I could locate one?
Thanks.
Kwackman
Re: SPST switch for old guitar
Postby Random Guitarist » Wed Jan 15, 2020 7:40 pm
Random Guitarist
Postby Random Guitarist » Wed Jan 15, 2020 7:42 pm
Random Guitarist
Postby Wonks » Wed Jan 15, 2020 7:43 pm
A photo would help, of the top and bottom of the switch, with a ruler or similar by it to gauge the size. It's difficult to get an idea of the size just from a description. (Have just Googled the guitar, and yes, they look like a standard Switchcraft-style selector switch, though possibly smaller).
With reference to switches etc., NC just means 'normally closed', which doesn't really apply to a switch, more to contacts in a relay showing the relay's unpowered contact positions.
I'm struggling at the moment to find anything suitable, as there are no Switchcraft-style 2-way switches showing up in searches. Almost all that size of switch are designed for fairly large current switching and so have a necessarily heavy switch action.
Postby Wonks » Wed Jan 15, 2020 7:46 pm
That's just a standard 3-way switch, which won't do the job. What's confused you is that it's actually described as two SPST switches, as its got two sets of contacts, but it's still a 3-way selector switch.
Postby Sam Spoons » Wed Jan 15, 2020 8:18 pm
I know you know this Wonky but for clarity, a Gibson style pickup selected switch has two poles and three positions, with the centre position having both poles [ON]. A 'normal' (for most other uses) three position switch has everything off in the centre position which clearly wouldn't work for pickup selection*. The SPST, DPST etc designation fails the test when trying to describe such a switch.
* I did manage to make it work on a travel guitar I built by wiring the two single coil pickups in series and used a three position DPDT mini toggle to short each out in turd, centre off meant neither pickup was shorted so both were active.
Postby Random Guitarist » Wed Jan 15, 2020 8:19 pm
Doh! Good catch
Random Guitarist
Postby Kwackman » Wed Jan 15, 2020 9:04 pm
Thanks for the replies.
I'm going to try to load pictures, in my next post.
Last time I tried this it failed, fingers crossed.....
Kwackman
Postby Kwackman » Wed Jan 15, 2020 9:09 pm
I think I've got it to work. Hopefully you can now see 5 photos?
This picture shows the top two switches in situ if it's any help.
Kwackman
Postby Sam Spoons » Wed Jan 15, 2020 11:09 pm
The position of the toggle suggests they have three positions, how many terminals/wires do they have?
Postby Kwackman » Wed Jan 15, 2020 11:12 pm
Sam Spoons wrote:The position of the toggle suggests they have three positions, how many terminals/wires do they have?
It has only two positions and only two terminals.
Kwackman
Postby zenguitar » Wed Jan 15, 2020 11:16 pm
Might be worth contacting Brandoni guitars. He bought the stock when the Eko factory closed. Eko made a number of Vox guitars so it is possible that they have an NOS replacement. No guarantees but worth a phone call or email.
http://www.brandoniguitars.co.uk/
The more I understand Music, the less good I get at it.
Postby Sam Spoons » Wed Jan 15, 2020 11:20 pm
Andy has got to the nub of the problem (as usual).
But it's interesting that the toggle appears to be central. If you can't find direct replacements I might be considering using the extra switch positions for extra features, or simply block some three way switches so they can't use the third position?
Postby Kwackman » Wed Jan 15, 2020 11:29 pm
zenguitar wrote:Might be worth contacting Brandoni guitars.
Thanks for that info Andy, I'll follow up on that. :thumbup:
Sam Spoons wrote:But it's interesting that the toggle appears to be central.
Yeah, when it's central, the two terminals are connected, and the guitar signal is untouched.
When the toggle is "down", the guitar signal's tone is changed.
There's a very good chance I'll never use it (or the overall on/off switch) but I'd like to see if I can get them working while I have it apart.
Kwackman
Postby Sam Spoons » Wed Jan 15, 2020 11:51 pm
I get that, I'm currently debating whether to remove the volume control from my '81 Brian Eastwood custom acoustic and fit a passive UST pickup or add a preamp to de-couple the volume pot. Doing the former will leave me with a hole near the heel but I'm using a Tone Dexter preamp which seems to work best with a passive pickup.
