PRS SE Hollowbody II
Postby BJG145 » Wed Feb 12, 2020 7:12 pm
I'm really liking the look of these.
Anbody want to talk me out of that, or should I keep daydreaming...? :beamup:
(Never played a PRS.)
Re: PRS SE Hollowbody II
Postby Wonks » Wed Feb 12, 2020 7:34 pm
It's a PRS. Don't do it. You'll only encourage them.
I always find them sterile and I really can't get on with their 'wide fat' neck - just doesn't work for me. Buy something with a bit of soul, even if it's not quite as cosmetically perfect.
Postby John Egan » Wed Feb 12, 2020 8:05 pm
Wonks wrote:It's a PRS. Don't do it. You'll only encourage them.
I've tried a lot of PRS guitars in shops,and I have found most of them to be unexciting, despite their first class build quality. However, about 18 months ago I bought a second hand USA S2 Vela, which has a single coil pickup in the neck and a coil-tapped Starla humbucker in the bridge. This one has a real vibe.Loads of character and stripped down looks - quite Tele-like in its way. I've also found that the PRS SE77 Baritones sound excellent.
Regards, John
John Egan
Postby ManFromGlass » Wed Feb 12, 2020 11:15 pm
After a few quick tests I find the necks work well for me. It’s easier for me not to mute open strings when I want them to be part of a chord. I haven’t test driven one for sound yet.
Do fingers get chunkier as we age?
Baritone? That sounds intriguing! 8-)
Postby blinddrew » Thu Feb 13, 2020 12:32 am
I have one of the first style semi hollows and really like it. I believe Music Wolf has one of these new ones and rates it very highly.
For what it's worth, I've never really got the idea of a guitar being 'sterile' or 'clinical'. But that might just be because i'm not a good enough player to appreciate it.
Postby John Egan » Thu Feb 13, 2020 12:50 am
blinddrew wrote:I have one of the first style semi hollows and really like it. I believe Music Wolf has one of these new ones and rates it very highly.
I've never claimed to be a good player and I'm worse now than I used to be, but for me a guitar needs to impress me after no more than 5 minutes playing and preferably in the fist few notes/chords.
I only got that from three PRS guitars : my S2 Vela; an SE277 Baritone; and an S! Starla with a Bigsby.
Regards, John
John Egan
Postby Sam Spoons » Thu Feb 13, 2020 12:54 am
I was about to type "don't, they're yuppy guitars" but then thought, if it lights your candle then buy it...... Life's too short and it's not a marriage, if you don't get on you can just sell it again*
* I fancied one for years, then bought a very nice Pac Rim rip off but that was enough for me to realise a PRS wasn't for me. I still don't know why but it just failed to capture my heart**
** Sorry for the 'pretentious git' moment.....
Postby Music Wolf » Thu Feb 13, 2020 8:25 am
I do indeed. In fact I had one of the very first SE Custom Semi Hollows to hit these shores (in blue), foolishly sold it then bought a second hand one (in natural, like Drew's I think).
I played this at one gig and liked it so much that I went out and bought the S2 version (the S2 has a trem)
My son now has the SE.
Very happy with the S2 but it is a Semi. It is essentially a solid body which has been carved out. The Hollow, which BJG145 needs to go out and buy today, is a genuine hollow (laminated construction. I believe that the wood is from the wood panelling salvaged from Harley St Doctor's consulting rooms :D ). I think that it has a block below the bridge but I can't be sure as the pages of the review in this month's Guitarist mag appear to have become stuck together.
Music Wolf
Postby Wonks » Thu Feb 13, 2020 8:35 am
Can I just mention that the Hollowbody II is made in China, so will be full of Coronavirus.
Postby Music Wolf » Thu Feb 13, 2020 8:40 am
Thus giving you 14 days of isolation where you can bond with the instrument.
Music Wolf
Postby Wonks » Thu Feb 13, 2020 8:42 am
So, it's to die for?
Postby blinddrew » Thu Feb 13, 2020 9:36 am
:bouncy: :clap:
Postby Dynamic Mike » Thu Feb 13, 2020 10:56 am
That's exactly how I feel about PRS, nicely put together just not very engaging. If you want character and attention to detail check out Duesenberg.
Dynamic Mike
Irrational beliefs justify unthinkable actions
Postby SecretSam » Fri Feb 14, 2020 8:35 am
I've got a PRS Zach Myers, made in Korea. One chamber, not two.
It has the smoothness of any set neck guitar with humbuckers. If you are looking for something twangy or single coil (or that buzzes when you switch the lights on) it's the wrong instrument.
However, to my ears and hands, it does a far better job than comparably priced instruments of similar style from Ibanez, Epiphone, Tokai. A proper es355 is better, but costs three times as much, so it should be.
You can find out whether the neck profile works for you in five minutes in a shop. I think it's perfect.
The only quirk is that they come with 9 gauge strings as standard, which is a bit thin for my taste. The nut will accept 10s and 11s. 11s seem to kill the tone on mine for some reason.
SecretSam
Postby CS70 » Fri Feb 14, 2020 9:12 am
Absolutely go for it. Life's too short. My 2006 SC and 2007 Custom 24 have been touring machines in their time - simply never a problem, barely needed a tuner. To this day, I can take 'em out of the case after months of not touching it and they usually are in perfect tuning and the setup is totally unchanged. Try that with the Fenders! :D
SEs didn't exist back then but nowadays I would bring one around in a heartbeat. From the ones I've tried in shops, the build quality and precision are astonishing and the price for what you get, even more.
As for any guitar, you need to like the neck and weight distribution, so try it. But the scale is just so and as of sound and feel, let me put it like this.. if you can't make it sing, it's not the guitar. ;-)
As for looks.. does it look porn-grade good? Yes it does. People who don't like that should go play bass. :bouncy:
Postby Music Wolf » Fri Feb 14, 2020 10:19 am
This morning I've taken the action down on my S2 so that it plays more in line with my Core and my SE Chris Robertson - and it's shifted it up a gear.
Music Wolf
Postby Dr Huge Longjohns » Fri Feb 14, 2020 12:27 pm
No, it's because the idea is total bollocks and you're quite right to reject it. It's all to do with how a guitar looks. People think that if it doesn't look like it was made in the 50s it's somehow lacking in, ahem, vibe. It's a marketing trick which amateur players and children repeat all day long on YouTube. It's the guitar version of 'vintage warmth'.
Dr Huge Longjohns
Postby Dynamic Mike » Fri Feb 14, 2020 12:34 pm
So you're saying every guitar feels the same to play? I don't think cost or kudos comes into it, I agree with that sentiment though.
Dynamic Mike
Postby Sam Spoons » Fri Feb 14, 2020 12:48 pm
Guitars all feel different to play but yes, much of our perception is down to looks. I freely admit I like the way my guitars look and would not have bought them if didn't look good to me. There is something in the name too but it's not cut and dried, I like my Gibson LP and my Brian Eastwood custom built acoustic because they feel 'special' for one reason or another but I also like my Squire bitsa Strat and my Mountain D45. Whatever it is I have a 'connection'* with all my guitars and that is important to me. But, that connection is equally as dependent on sound and feel and if a guitar doesn't play well or sound good I won't make that 'connection' and either won't buy or will, sooner or later, sell the guitar in question.
* Sorry, another 'pretentious git' moment :blush:
Postby Wonks » Fri Feb 14, 2020 1:22 pm
I very much disagree. It's got nothing to do with looks for me (and a PRS could easily be a 50's guitar). And I'm certainly not influenced by YouTube videos (well ones that don't contain hard provable facts). It's all about how a guitar sounds and responds to me. OK, if I don't like the looks then I probably wouldn't get one, but that wouldn't stop me acknowledging the guitar as a good one. Arkieboy's old Les Paul Signature is a lovely playing and sounding guitar, but it really is fugly to me!
I must admit to not having tried that many PRSs (as very few have the wide thin neck that I can get on with), but whenever I do, There's never been a 'wow' factor in how it performs. Maybe swapping out the pups would do it, but on some models, like the 408 I fettled, you can't easily do that without major changes.
PRSs really are marmite guitars.
