Boss SY1000 mini review
Re: Boss SY1000 mini review
Postby BobTheDog » Tue Apr 28, 2020 8:01 pm
Aha, I got one from GAK, coming Thursday.
BobTheDog
Postby BobTheDog » Sat May 02, 2020 10:54 am
Hi Guys that have one.
I'm guessing my screen isn't quite right, I thought I would check before returning it :(
Any info would be appreciated.
Cheers
Andy
BobTheDog
Postby Music Wolf » Sat May 02, 2020 11:47 am
Has the 'contrast' been turned to max?
Music Wolf
Postby zenguitar » Sat May 02, 2020 12:27 pm
That MIDI socket won't work ;)
Yogi Berra
Postby BobTheDog » Sat May 02, 2020 1:44 pm
Music Wolf wrote:Has the 'contrast' been turned to max?
That pic is on 6, the only setting that makes it go away fully is the minimum And then I can’t read anything!
BobTheDog
Postby arkieboy » Tue May 05, 2020 6:57 pm
It’s a known issue on some units. There are reports of a fix.
https://www.vguitarforums.com/smf/index ... ic=27915.0
arkieboy
Postby BobTheDog » Thu May 07, 2020 5:05 pm
Thanks for the link, will have a look...
BobTheDog
Postby ManFromGlass » Sun May 24, 2020 1:47 pm
zenguitar wrote:That MIDI socket won't work ;)
This almost made the coffee come out my nose! Today’s guffaw. :D :clap:
Postby BigRedX » Tue May 26, 2020 12:45 pm
I'm seriously interested in one of these. Unfortunately there does not appear to be a pickup available that will work with either of the instruments I would like fit it on.
The Burns Barracuda vibrato mechanism won't allow me to fit a GK-3 close enough to the bridge saddles - AFAIKS 20mm is the furthest away that works reliably. The Eastwood copy of the Shergold Six String bass has a 13mm string spacing at the bridge and the GK-3 only accommodates up to 12mm and the GK-3B has a minimum of 16mm.
I've looked at the possibility of replacement piezo saddles but the bridges on both instruments are very much non-standard.
Is anyone doing custom spaced GK pickups?
BigRedX
RockinRollin' VampireMan
Postby arkieboy » Thu May 28, 2020 6:50 pm
BigRedX wrote:Is anyone doing custom spaced GK pickups?
I think your best bet might be https://www.cycfi.com/
http://www.ubertar.com/hexaphonic/products.html I’ve seen builds using these too - I think they do custom builds
arkieboy
Postby zenguitar » Thu May 28, 2020 7:19 pm
Those look like very useful links. Thanks for that, I've got them bookmarked now :thumbup:
Yogi Berra
Postby BigRedX » Fri May 29, 2020 10:48 am
Thanks I'll be exploring these options when I have the Eastwood bass in my hands and actual string spacing and other dimensions.
BigRedX
