2 channel compressor advise?
For a long time Ive been using an original Behringer MDX in de inserts of my 2 channel bass input module, but I like an open top-end and the MDX adds a lot of hiss, which is not the most practical combination, of course. I dont mean that it amplifies hiss coming from the instruments. With nothing plugged in, the MDX is completely silent when bypassed, but adds serious hiss when processing is turned on, so this hiss must be created by the MDX's circuitry itself, since there is no source of hiss going into the compressors.
But its an old unit, its time for something new.
I use 2 compression stages in my signal chain and the one at this position is mainly used to prevent a too big volume boost going into the preamp, increasing the amount of drive and overal volume too much, when I turn up the mid EQ on my bass. With the mid EQ I want to color the sound, not increase overal volume a whole lot. A bit further on in the chain is a 2nd compressor to provide extra punch, so the main objective of the 2 channel compressor is keeping signal levels in check, not punching up the bass sound. Although I dont see extra punch as a bad thing ;)
Could someone advise me on a 2 channel (preferably rack-mountable) compressor, that works well for bass, that doesnt add annoying levels of hiss to the signal? Looking at current prices, I wasnt thinking around up to a couple of 100 bucks, but if the unit I need costs more to do the job right... so be it.
