blinddrew wrote:Another plus for the snark, it has a built in mic as well as the vibration feature. It works ok for the most part as well.
Problem solved.
shufflebeat wrote:To the OP
For the record, tuning an accordion should only be attempted by a qualified veterinarian.
SecretSam wrote:shufflebeat wrote:To the OP
How can you tell?
adrian_k wrote:SecretSam wrote:shufflebeat wrote:To the OP
How can you tell?
You check it against some bagpipes, or a banjo.
