I have an overflow of pedals; don't mention Black Friday! :shh:
So I need a second power supply to handle say 6 or more.
They all seem to be the Boss style connectors which is -ve centre I believe.
This is for home use only so it doesn't need to be that portable.
Something compact and flexible would be good that comes with the power leads.
Not looking for high end so more the value end but not too cheap to be any good.
Are these sort of designs any good?
https://www.amazon.co.uk/Caline-CP-05-G ... 018KGSYJE/
https://www.amazon.co.uk/Donner-Guitar- ... 0778GPWMR/
They look more flexible than these kind:
https://www.amazon.co.uk/Mr-Power-Guita ... 01KJ5XDQ8/
I'll have to go through all the pedals to check their mA ratings before making a final decision. I'm looking to choose a style of P/S first and then hone in on a precise model.
What compact power supply to buy to run 6+ pedals?
• Page 1 of 2 • 1, 2
- Agharta
- Jedi Poster
Re: What compact power supply to buy to run 6+ pedals?
I use that exact Caline, kindly given to me by a member of these forums! I was originally planning to upgrade to a proper ground isolated PSU, but I’ve had zero issues with the Caline so I plan to keep it.
garrettendi - Frequent Poster (Level2)
"I mean, Led Zeppelin didn't write tunes that everyone liked. They left that to the Bee Gees" - Wayne Campbell (Wayne's World)
I'd go for the Donner style as it has isolated outputs (or at least it says it has). Almost guaranteed to be required if you have at least one digital pedal to avoid ground loop noise, but even with analogue pedals, you normally get less noise if using isolated outputs.
Wonks - Jedi Poster
Buy by mail order and if you get noise return it. I have a Harley Benton which seems to be fine.
https://www.thomann.de/gb/harley_benton_powerplant.htm
Sam Spoons - Jedi Poster
Thanks guys. I'll go for an isolated one then.
Is £28 a reasonable price to pay? Not too cheap!
I've at least heard of Donner which might not mean anything!
I might need a few longer power leads for flexibility so hopefully they are standard sized both ends; obviously they are standard on the inputs for the pedals.
Not sure if this works just to extend the length for one pedal?
https://www.amazon.co.uk/Mooer-PDC-2A-P ... 00MZFO2J8/
Edit:
I checked and the cables in this add-on kit are 60 & 80cm which is fine.
https://www.amazon.co.uk/gp/product/B07T89Y1G4/
The ones that come with the actual P/S seem to be around 30cm.
Edit:
- Agharta
- Jedi Poster
Bear in mind that returning things to Thomann might not be so easy in the new year unless a trade deal is reached. We should know soon on that front, but what any likely repercussions will be may take longer to discover.
Wonks - Jedi Poster
I have at least 3 pedals which are well over 100mA so I will need to look at something else as the Donner only has 2 500mA outputs and the rest are 100mA.
I'll need to check my other setup as that seems to only be 9W across its 7 outputs.
I'm in danger of overloading that with the 300mA units although many of the others are very low amperage.
I'm not planning on using Thomann but it's good to be reminded of that . :thumbup:
- Agharta
- Jedi Poster
So three digital pedals, which almost certainly means you need isolated outputs. This, plus larger current capacity, is when it all starts to get expensive!
Wonks - Jedi Poster
It seems as if many of the cheaper ones say they are isolated but are not.
This looks more flexible power output wise but is it really isolated?
https://www.amazon.co.uk/Getaria-Guitar ... 08594PWKD/
- Agharta
- Jedi Poster
From the comments it looks not. 'Isolated' here means that there's a voltage regulator and short circuit protection for each output, but as the outputs have a common ground, they can still create ground loops.
With true isolated outputs you can use a correctly configured cable to link two outputs to give double the voltage.
Wonks - Jedi Poster
Thanks.
So this kind of thing or is there something under £100 that does the job?
https://www.amazon.co.uk/Mooer-Isolated ... 07C1JFF45/
- Agharta
- Jedi Poster
This 'homage' to a Voodoo Labs Pedal Power 2 Plus would be ideal if it had 3, not just two high current outputs. Well under half the price of the VL units. I have two of the VLPP2+ units.
https://www.amazon.co.uk/Donner-Guitar- ... 159&sr=1-7
But it does miss the mains output power socket that allows you to daisy chain more supplies together and feed them from one mains cable, and unless someone tests one, there's no way to really tell how isolated the outputs are. If they have done a near-straight copy of the design, then it will be fine. If it just looks like one, then they'll have a common ground again.
Wonks - Jedi Poster
That looks fine. You do end up paying more for numerous high mA outputs.Agharta wrote:Thanks.
Wonks - Jedi Poster
Might not be what you asked about as such but - the Boss BCB-60 pedal board comes with power supply and power leads and interconnects and can be had for £106.00. Bargain! I bought one earlier this year and finally no more floor spaghetti.
Gronow - Regular
Once it sounds right stop!
Gronow wrote:Might not be what you asked about as such but - the Boss BCB-60 pedal board comes with power supply and power leads and interconnects and can be had for £106.00. Bargain! I bought one earlier this year and finally no more floor spaghetti.
Thanks. I already have one of those so am looking for something more compact this time for the overflow.
- Agharta
- Jedi Poster
