Sam Spoons wrote:I wonder if Dave meant that or, maybe, touching the tip of the guitar lead and the resultant loud buzz we are all familiar with?
Indeed so Sir but yes, Speakons at these power levels to be sure.
Nothing is so dishonest as amp output ratings in the UK and the US.Wonks wrote:So the figures used are heavily manipulated and used to show the biggest output figure and smallest consumption possible.
The Red Bladder wrote:I sometimes joke that you could take a piece of cheese and stuff a few wires into the damn thing and call that a 1000-Watt amplifier. I wouldn't be too far wrong!
MOF wrote:Here’s hoping Hugh, or someone else well versed in electronics, will explain how this amplifier gets more power out than its input.
Even the RMS figure of a 500watt peak doesn’t work for me.
The Red Bladder wrote:Nothing is so dishonest as amp output ratings in the UK and the US.Wonks wrote:So the figures used are heavily manipulated and used to show the biggest output figure and smallest consumption possible.
Take your amp, feed a sine wave into the damn thing and feed the output into a Watt meter and an oscilloscope. Now crank-up the volume and be amazed at how much BS you are being fed.
The sine wave will clip (get a flat top) and the Watt meter will show you a tiny fraction of the so-called 'peak' or 'music' power. (What happens over a few milliseconds is pure fugazi!)
Wonks wrote:Well, with a sine wave, times your peak voltage power reading by 0.707 (or divide by root 2 - it's the same thing) to get the RMS value.
So that would be around 70W RMS.
