EHX Tri Parallel Mixer
Postby AMOS63 » Tue Jan 26, 2021 11:39 pm
I have a question for anyone that uses one, in the mode where you can send signals to two amps, can the EQ knob be used or just the send? The manual and the videos I've seen only mentions the send. I don't own one of these yet and I wanted to make sure what it can do and can't do before I order one.
AMOS63
Re: EHX Tri Parallel Mixer
Postby Sam Spoons » Wed Jan 27, 2021 4:27 pm
Looking at the manual the eq is in the return path of each loop so can't only be used when sending a signal to two amps.
Postby thefruitfarmer » Thu Jan 28, 2021 1:58 pm
If you want to run the signal to two amps then you would do better with a specific box with ground lift and phase reversal really.
Radial Twin City does it
Brightonion does it cheaper
https://www.brightonion.co.uk/active-aby-pedal-with-isolated-second-output/
thefruitfarmer
Postby AMOS63 » Sat Jan 30, 2021 3:11 pm
Thanks for the replies!
AMOS63
