Too many pedals.
Re: Too many pedals.
Postby Arpangel » Mon Apr 26, 2021 7:07 am
Wonks wrote:
Arpangel wrote:Of course it’s OK, I have three tooth brushes, and they always come in handy.
I didn’t know you only had three teeth.
That’s a whole new perspective, of course, we could have a set of pedals for each guitar (or keyboard) we own, that’s a good way to justify owning so many, purely on a convenience footing, you could even have pedals just for gigging, and studio, that way you don’t have to keep disconnecting pedal and PSU's, I’m already doing this, it works well.
Postby Wonks » Mon Apr 26, 2021 7:42 am
Quite a few people I know have different pedalboards for different situations. And with so many good, cheap Chinese clones of classic analogue pedals available for £20-£25, it doesn't have to cost too much to do so.
Postby Arpangel » Mon Apr 26, 2021 7:51 am
Wonks wrote:Quite a few people I know have different pedalboards for different situations. And with so many good, cheap Chinese clones of classic analogue pedals available for £20-£25, it doesn't have to cost too much to do so.
Yes, I’m thinking of trying those Behringer ones, also the Mooer ones, but what I’m really looking for is an all in one solution, a small synth, with every synthesis option built in, every effect built in, and a fully featured audio recorder and editor, built in, that weighs a few ounces, is battery powered and that can be played in bed, on a pillow.
:think: :)
Postby Random Guitarist » Mon Apr 26, 2021 9:24 am
I can certainly identify with this having recently sold a pedal. It had sat on the office shelf for 15+ years without 9v troubling its slumber. I only plugged it in to test it, but I was still reluctant to put it in the post. On any sensible level it's ridiculous to want to hang onto these things, but the emotions are a different thing.
I have pedals I know I will never use again. but they are still on a shelf. Swivelling round on the office chair I can see 16 pedals from where I sit. Maybe 4 of them I will use again. I can pretend that they will be a source of inspiration some day, but I kind of doubt it.
The only other possibility is if I make up a secondary pedal board. But that makes no sense. I would build a chain of pedals that I rejected from my main pedal board.
I am convinced now, it's time to sell, or maybe create a small pedal board . . .
Random Guitarist
Postby Arpangel » Mon Apr 26, 2021 9:33 am
Random Guitarist wrote:I can certainly identify with this having recently sold a pedal. It had sat on the office shelf for 15+ years without 9v troubling its slumber. I only plugged it in to test it, but I was still reluctant to put it in the post. On any sensible level it's ridiculous to want to hang onto these things, but the emotions are a different thing.
It is true, certain pedals have a deep emotional connection, I bought some just as I was moving into my new place, and they sat in their boxes for weeks, owing to building works going on, so I was really anticipating using them, so all that goes through my mind, it bonds you to things, emotional and important associations.
Postby ManFromGlass » Tue Apr 27, 2021 2:28 am
It’s true. I just got a Boss SE-50 up and running and the sound took me right back to younger days.
And
An old toothbrush is perfect for getting the dust out of pedal crevices!
Postby Arpangel » Tue Apr 27, 2021 8:12 am
ManFromGlass wrote:It’s true. I just got a Boss SE-50 up and running and the sound took me right back to younger days.
And
MFG, you know that SE50 I bought recently from a "reputable dealer" it had a fault, presets wouldn’t hold in memory, had to change the battery, all is now fine.
But it just goes to show that they hadn’t tested it, they would have seen on fire-up that the screen was all hieroglyphics.
Postby Wonks » Tue Apr 27, 2021 8:41 am
It had obviously been used by the dealer’s mummy.
Postby Arpangel » Tue Apr 27, 2021 9:32 am
Wonks wrote:It had obviously been used by the dealer’s mummy.
That’s bad Wonks, I expect better from you!
Postby Wonks » Tue Apr 27, 2021 10:26 am
OK then; it was all part of a pyramid selling scheme .
Postby blinddrew » Tue Apr 27, 2021 10:35 am
That joke is older than the pharo...
Sorry. I'll see myself out.
Postby Wonks » Tue Apr 27, 2021 11:14 am
Tut tut.
Postby ManFromGlass » Tue Apr 27, 2021 6:51 pm
n common?
And
The clip that held the battery in mine was bent so the battery was loose. Easy fix. Hieroglyphs now back to english after the factory reboot sequence..
Postby SecretSam » Thu May 06, 2021 8:54 am
You could always donate some of the excess pedals to poor people in Africa. I would be happy to accept them on the continent's behalf.
SecretSam
Postby Wonks » Thu May 06, 2021 9:04 am
And obviously we'd have to take all your money, house and other possessions away first to make you poor so that you could accept them.
PreviousNext
