Innovative sounds & recording methods
Re: Innovative sounds & recording methods
Postby gryfyx » Wed Jan 20, 2010 8:12 pm
Martin Walker wrote:I love using moving mic/speaker techniques like that Elf 8-)
For the less adventurous who want to avoid damaging their mics through accidental string snapping, just set up a couple of mics a few feet apart and then move your source around manually while you record - this works great with bells, percussion, and singing bowls in particular.
Instant Doppler shift if you can do it quickly enough :bouncy:
Wow, it seems lot many are doing this.
would definitely try.
:shock:
gryfyx
Postby gryfyx » Wed Jan 20, 2010 9:27 pm
Hey guys whoever is keen to learn circuit bending can check this out: http://www.anti-theory.com/soundart/circuitbend/
Another nice recording technique, although this might turn out to be a bit pricey-- Take a "pressure zone microphone" and attach it to any percussion instrument's body and then see the magic of clarity in the low frequencies. Can make some really, really bouncing and heavily pounding kicks.
gryfyx
Postby Martin Walker » Thu Jan 21, 2010 3:42 pm
AuralSerenity wrote:Hey guys whoever is keen to learn circuit bending can check this out: http://www.anti-theory.com/soundart/circuitbend/
That's an interesting one thanks.
It needn't be expensive - I seem to remember Tandy (Radio Shack) having some very reasonably priced Pressure Zone Microphones some years back that people were using to record all sorts of stuff. Here's a thread from our previous (version 2) forum on the subject:
http://sound-on-sound2.infopop.net/2/OpenTopic?a=tpc&s=215094572&f=884099644&m=830106272
...and here's a useful history of the PZM:
www.uneeda-audio.com/pzm/index.htm
Postby gryfyx » Thu Jan 21, 2010 5:33 pm
Thanx Martin.
I dont know why but out here in India PZM's are not all that cheap.
Off-topic query removed and replied to by PM - MW
gryfyx
Postby The Elf » Thu Jan 21, 2010 7:00 pm
Martin Walker wrote:It needn't be expensive - I seem to remember Tandy (Radio Shack) having some very reasonably priced Pressure Zone Microphones some years back
I still have a pair of Tandy PZMs, bought way back in the 80s, modified for balanced connection and phantom power (thank you Paul White). Can't say I use them often, but they were a revelation at the time. We got some amazing drum recordings with them taped to the walls of the live room.
Postby Shreddie » Sat Jan 23, 2010 9:42 pm
I've done alot of stuff like this including many of those posted... Not always using mics either!
I've recorded industrial machinery, squeaky gates, almost everything in my tool shed (well worth doing) and kitchen, my dogs grumbles and barks, animals birds and insects etc. I've recently taken to setting my H4 to record, popping it in a pocket then going about my daily activities as usual... Me spitting out toothpaste makes a pretty good snare! Regarding the recording of insects, I have a cheap (and not that good) tie clip mic that I got from Tandy about 15 years back. I've attached that to a thin aluminium bar and poked it into ants nests as well as attached it to flowers to capture the sound of bees and other feeding insects very close up. That mic really is good for getting into inaccessible places and capturing quiet sound sources at close quarters... I really must get a better one though.
Another thing I do is use an electro-magnetic pickup designed for recording phone conversations (a guitar pickup works just as well) and hold it near all sorts of electrical equipment. Computers and digital gear can provide all sorts of strangeness, some very useful and playable when assembled into patches. Small battery powered electric motors can also sound amazing when captured this way with a bit of chorus and reverb.
Shreddie
Postby gryfyx » Sun Jan 24, 2010 8:46 am
Shreddie wrote:I've done alot of stuff like this including many of those posted... Not always using mics either!
Thanx Shreddie. Please share some more.
Well, Motor of the tooth brush can generate the noise of mosquito buzzing around your head. You need to touch it on any surface to make variations.
Best bass sound I ever made was through the couple of PZM's sticking on the drum's body and a couple of small diaphragm mics in xy position near hats. Feed through the pzm was on a separate track and when I checked it later, I was amazed by the loud, crisp and much bigger kick sound, even a part of the snare was almost kick like. Entire bass seem to have more depth. Fascinating thing was, I still had quite a headroom available. :)
gryfyx
Postby Shreddie » Mon Jan 25, 2010 2:36 am
AuralSerenity wrote:Thanx Shreddie. Please share some more.
There's not really much more to share, besides, I don't want to give away all my secrets! Although I usually record at 96k when I fancy getting creative with something, that means I can slow it down without loosing as much quality.
The way I see it, just experiment and keep an open mind. Nothing is out of bounds when you're getting creative with sound IMHO.
Speed stuff up, slow stuff down, whack it though strange effects, pop it in a synth and mangle it up, layer another sound alongside it, record that then start again if you wish!
Just think about it, a ten minute recording of you just hanging around on your local highstreet on a busy Saturday could yeld 1000 sounds. If you take just one of those sounds and put it into a synth you can come up with a million permutations.
When you're getting creative with sound, the world really is your lobster!
Shreddie
Postby Fibes » Sat Jan 30, 2010 2:33 pm
This thread is bang-on, there are a lot of sounds out there, it's simply a case of knowing the best way to capture, and then utilize those sounds. Sometimes the process of capturing a sound (as in the swinging mic idea, or sustaining a particular portion of a sample) can reveal fresh sounds and harmonics that were previously hidden.
Not a new idea by any means but I use Guitar Rig a lot to manipulate sounds and loops, the GUI is perfect for experimenting with complex effects chains, albeit largely limited to guitar stomp boxes and amp models.
Fibes
Postby Richie Royale » Mon Feb 01, 2010 10:04 am
Not something I've used that much, but these days most phones have the ability to record, and some of them are low quality enough to change the tone of a sound. You can get some interesting percussive tones from random sources. I've also used one of those little sampler mics, a gimmicky toy, but again they change the tone into something unique.
Richie Royale
Postby discomb » Mon Feb 01, 2010 10:11 am
Over the weekend I took my zoom H4 to my old parents house and recorded the sounds of doors opening and closing. very strange hearing sounds I used to hear for 20 odd years of my life coming out of my monitors!
I was in the garden waiting to record a tube train going past and a police helicopter appeared and hovered literally overhead! that sounds pretty good.
Recently I also sat at the back of a bus on the journey home from work - some very interesting harmonics in a powerful diesel engine :)
discomb
Postby The Bunk » Tue Feb 02, 2010 12:41 pm
...a wooden spoon on the rim of a saucepan gives a lovely soft percussive sound; you know, when you've just stirred the contents and are tapping what's left on the spoon back into the pan. It helps to soften the sound if the spoon is old (which I guess means its soaked up a lot of water in its time) and the saucepan needs to have something in it - seriously! (usually chicken curry in my case)
The Bunk
Postby Martin Walker » Tue Feb 02, 2010 5:59 pm
Hi The Bunk!
I hope you're creating your hi-hat sounds from breaking papadums as well.
The kitchen is a wonderful source of audio possibilities, from the saucepans you mention to cutlery, metal trays found inside the oven, glasses used as percussion/bells, and of course cutting up vegetables 8-)
Postby The Bunk » Tue Feb 02, 2010 6:17 pm
Martin Walker wrote:Hi The Bunk!
hmm, not tried those yet, but it's a little-known fact that the famous "aaaaaaargh" in Comfortbaly Numb is in fact taken from someone sampling my chicken vindaloo....
The Bunk
Postby Zukan » Fri Feb 12, 2010 6:34 pm
I too had your vindaloo and am the source for the final impact moment in the film Comet.
Zukan
