Innovative sounds & recording methods
Re: Innovative sounds & recording methods
Postby Martin Walker » Tue Jun 19, 2018 5:07 pm
Pendulum Music Steve Reich 1968
This is an oldy but goody from the famous minimalist composer.
Now listen to the fascinating results: www.youtube.com/watch?v=fU6qDeJPT-w
Postby ManFromGlass » Thu Jun 21, 2018 11:10 pm
Pulling out the power chords instead of turning the amp off?
Ah showbiz and the minimal possibility of fire or electrocution!
Exciting!
Postby Martin Walker » Wed Jun 27, 2018 2:03 pm
Sonica: Infinite Lives
"Robots, kinetic sculptures, modified technology and real live sea monkeys populate Robbie Thomson’s new work, inspired by the farthest extent of our perceptions. Infinite Lives turns Kings Place into a science laboratory, as the weird and fascinating objects come to life with special lighting effects, video footage and an irresistible electronic beat, experimenting with the limits of our own consciousness."
Love the kinetic head!
Postby Martin Walker » Tue Jul 17, 2018 4:04 pm
The Eggiophone
"The Eggiophone is a fully chromatic controller instrument made out of plastic eggs, conductive black paint made by Bare Conductive and a Teensy microcontroller. In addition to the pitched eggs there are 3 potentiometer knobs and 5 momentary buttons which I use to move up and down octaves and as gated loopers. As the Eggiophone is a midi controller it can be used to play any sound in the world when connected to midi audio software such as Ableton, Logic, Reason etc via a standard USB cable."
Now watch it in action: https://www.youtube.com/watch?v=dk1Nyz_MXiM
Ooh, I do love people who create bizarrely new instruments like this! 8-)
Postby blinddrew » Fri Jul 20, 2018 9:25 pm
I love stuff like this. :)
Postby Martin Walker » Wed Aug 08, 2018 8:25 pm
UkuRobot - The Godfather Theme
Here's another innovative recording method - UkuRobot is a programmable ukulele player. It's a little pedestrian, but the shot of its mechanisms is certainly intriguing, and I suspect it's capable of a lot more.
www.youtube.com/watch?v=dWJ28uBflFg
Postby pettrer » Fri Aug 10, 2018 7:48 pm
gryfyx wrote:
4. I once stood on a rail bridge and recorded the passing train(I was dangerously close to the train, hence I'll not recommend this). Anyhow, I ended up not using it anywhere. It wasnt that good.
I live by the railroad. In May, I was working on a song using my Logitech headset in the garden. I started recording the trains and the crows flying around.
Then I ran these sounds through GGate (to get rid of noise between takes) and finally I put MSpectralDelay on this, with the UFO preset at 50%. Worked wonders for my mix. :thumbup:
pettrer
Postby pettrer » Fri Aug 10, 2018 7:57 pm
Pete Kaine wrote:
Richie Royale wrote:I once recorded a printer/photocopier at work which when it had run out of paper, would make a very robotic/mechanical sound and then beep in a kind of flatline way.
Printer Jam by Mistabishi
http://www.youtube.com/watch?v=is-HVxmUELQ
One of the best videos I saw last year with some pretty cool sampling.
My GOSH what a video! One thing's for sure: to find time for that sort of video, they must be single. :D
I used to work in the office for the Swedish folk music association. Our printer's sound was a very clean tritonus (the devil's interval). I couldn't stand it but no one bothered to replace it... :D
pettrer
Postby blinddrew » Fri Aug 10, 2018 8:54 pm
Can't beat a bit of technical lego. :)
Postby Folderol » Fri Aug 10, 2018 10:04 pm
I've always wanted to record both sound and video of heavy industrial plant in operation. These sounds and sights can be incredibly hypnotic.
In the industry where I've worked for a good many years, you've got everything from printing presses, magazine binders, leaflet and packet folder/gluers. Then there are the big daddy cardboard box die cutters slowly and endlessly stomping out intricate shapes. All of this under the same roof.
Each has it's own rhythm which you pick up as you move from one area to the next, but just occasionally there is the totally magic instance when they all synchonise. It used to be that you'd see grins on peoples faces, but not any more - which is rather sad.
Postby pettrer » Fri Aug 10, 2018 11:06 pm
Folderol wrote:I've always wanted to record both sound and video of heavy industrial plant in operation. These sounds and sights can be incredibly hypnotic.
It would be interesting to hear a composition based on this experience -John Adams' Different Trains comes to mind.
I remember how my music club in high school found an abandoned factory in 1990 and went there to sample things. :) We were about twenty kids and suddenly an instrumental piece emerged of its own, not totally unlike the photo copier stuff but even more industrial.
Then the night watch came and pointed at us with his big flashlight whereupon we ran off.
The track actually became the intro to the yearly school rock tape. Those were the days! :D
pettrer
Postby Martin Walker » Wed Aug 15, 2018 1:44 pm
and the wind was like the regret for what is no more, by João Costa
"This work consists of a set of sixteen bottles – with air blowers attached to each one of them – and a wind vane. The vane is fixed on the outside of a window and detects the direction the wind is blowing. Inside of the room, the motor starts blowing air into the bottle that corresponds to that particular direction. This event generates a smooth sound, and each direction has its own pitch. The bottles are arranged in a circle, similar to the shape of the compass rose, depicting the eight principal winds and the eight half-winds."
I'd love to hear more polyphonic music created by this installation, but to do that the wind would have to blow in several directions at once :(
Postby blinddrew » Wed Aug 15, 2018 8:52 pm
More triggers set at different corners of the building?
Postby Martin Walker » Thu Aug 16, 2018 5:02 pm
blinddrew wrote:More triggers set at different corners of the building?
Yep, that would work beautifully Drew! :thumbup:
Postby Martin Walker » Thu Oct 11, 2018 1:41 pm
Loop | Motors, Magnets and Motion: Electronic Music Instruments from the Physical World
Just had to post this, as it's SO inspirational to anyone who fancies some new sounds of an electroacoustic nature.
Bravo to these three pioneering musicians and their instrumental creations :clap:
https://www.youtube.com/watch?v=hJHwhb9 ... e=youtu.be
