Invented new sound synthesis techniques
Re: Invented new sound synthesis techniques
Postby Agharta » Sat Aug 26, 2017 11:15 am
Very interesting. I watched a few videos and will download some of your software when next at the PC.
Thanks for sharing.
Agharta
Postby Martin Walker » Mon Aug 28, 2017 8:01 pm
Wow, that's fascinating stuff! :clap:
Nested Hyberbolic and Trigonometric functions synthesis is certainly versatile.
Bravo the mathematician - if only numbers had been so creative when I was still at school ;)
Postby Eddy Deegan » Tue Aug 29, 2017 8:37 pm
Great stuff... the way that the waveform changes with NHT when you modify the arguments reminds me a bit of FM synthesis for some reason (sort of modifying one wave using another).
The proof of any synthesis model is surely in the listening thereof and the tones emitting from your project are very impressive considering you're building your own engine.
Not directly related to NHT, and I'm no mathematician (a bit of trig, and mental arithmetic is about as far as I can go comfortably) but as you seem to be much more comfortable in number-world, I was wondering if there is any mileage in using differential calculus somehow to generate a set of waveforms from the derivatives of a function across its domain in steps of varying sizes - these then could be merged/modulated/spangulotomised in creative ways to render a timbre. Maybe that's a bit random, and to be honest I don't know enough about it to offer anything more than a naive suggestion but hey :)
Some of my musical works.
Postby doctornash » Fri Sep 07, 2018 2:50 am
Here's the latest from my ongoing quest to discover and implement new sound synthesis techniques. The video explains and demonstrates the generation of sound waveforms from the motion of the vertices of rotating 3D-modelled objects. I've called the app 'Rotatosound' (originally thought of 'Rotosound' but that's already the name of a guitar string manufacturer) which implements this 'POVROS' (POlygon Vertex ROtation) sound synthesis method.
doctornash
Postby Martin Walker » Fri Sep 07, 2018 3:16 pm
Wow - POVROS is certainly different ! 8-)
Postby doctornash » Tue Jun 11, 2019 6:55 am
Have been experimenting with beating sine waves. The results have been promising enough to create a sound engine from (which I'm doing for my next synth).
Here's an example
This phenomenon is a paradox, because the generated frequency spectrum in each case is static - there are no external modifiers like ADSRs or LFOs operating to change which sine waves appear in the spectrum over time (and/or their relative amplitudes).
It is just a certain number of sine waves, all of equal amplitude, generated with a certain spacing and that's it. YET instead of a constant tone, one hears a complex evolving soundscape due to the sine waves beating against each other.
Another example of a synthesis technique about which there is very little in the literature, so had to do something about that :D
doctornash
Postby Martin Walker » Tue Jun 11, 2019 11:15 am
Ooh - I LURVE these evolving sounds 8-)
Well done that clever man! :clap:
Users browsing this forum: DGL.
