Aphex Twin / Air - what vocoder is this?
Postby Dan LB » Wed Sep 13, 2017 8:43 pm
Can anyone tell me what vocoder was used on the track 'How Does it Make You Feel' by Air from the album 10,000Hz Legend?
https://youtu.be/i0vl-7L-2Ow
The same effect can be heard at the end of Aphex Twin's 'Ventolin (Crowsmengegus Mix)' @5.13
https://youtu.be/145FCNfigA4
Thanks in advance!
Dan LB
Re: Aphex Twin / Air - what vocoder is this?
Postby baward » Thu Sep 14, 2017 10:41 am
It sounds identical to a Korg VC-10, as heard on 'Vocoder' by Isao Tomita (Bermuda Triangle, 1979) at the start of https://www.youtube.com/watch?v=_i2tdReLOeM
baward
Postby Dan LB » Thu Sep 14, 2017 1:31 pm
Thanks baward.
On second thoughts I don't think it's actually a vocoder but a speech synthesis engine of some sort.
Dan LB
Postby Dan LB » Thu Sep 14, 2017 3:56 pm
Ok I've found something that does it
https://codepen.io/matt-west/pen/wGzuJ
Select 'whisper' as the voice.
Dan LB
Postby Tomás Mulcahy » Thu Sep 14, 2017 4:13 pm
Apple Mac OS X text to speech. Select the voice you want in System Preferences. It still has the older ones there, that Air used on that track.
Tomás Mulcahy
madtheory creations
Soundware Shop
Postby Dan LB » Thu Sep 14, 2017 5:07 pm
Tomás Mulcahy wrote:Apple Mac OS X text to speech. Select the voice you want in System Preferences. It still has the older ones there, that Air used on that track.
Thanks Tomás. Had it under my nose the whole time!!! :headbang:
Dan LB
