the latest Behringer-gate
Re: the latest Behringer-gate
Postby Eddy Deegan » Fri Jan 17, 2020 10:58 am
As I'll be doing quite a lot more modular stuff in the near future I'm very interested :thumbup:
Some of my works
Postby DGL. » Fri Jan 17, 2020 1:38 pm
I do like that Behringer are doing the joke of sticking B on to the front of most of their clones (like Boog, Barp, Borg Etc.) and are claiming their announcements are coming from "The Banaheim Convention Centre!"
DGL.
Postby DGL. » Fri Jan 17, 2020 5:17 pm
https://www.youtube.com/watch?v=XofTuxGghuM
Modular 25/35/55 series, 20 modules in total, authentic recreations of the old Moog modular modules in eurorack form. Also new is a 1 unit PSU with external power brick designed for unpowered modular cases.
DGL.
Postby IAA » Fri Jan 17, 2020 6:44 pm
Crikey :o :o
I can see some of this heading my way. Oh my.
IAA
Postby Folderol » Fri Jan 17, 2020 7:06 pm
Well, I'm afraid that modular kit does nothing for me at all, but I can appreciate the work they've put into this. The modules look well built, and the legends are very clear - no squinting with a torch and magnifier in dim light.
Also, the man himself looks genuinely excited as he describes it all.
Postby The Elf » Fri Jan 17, 2020 7:36 pm
I've avoided modular so far, but if I could build a 'Roland' System 100, or a 'Moog' 55 for less than the price of a secondhand car I might just break ranks.
But I want a case with a mains connector!
Postby IAA » Fri Jan 17, 2020 7:39 pm
..of course you do!! ;)
I’ve resisted modular too but......for the price if the Korg ARP 2600 you could get an absolute barrow full.
IAA
Postby Folderol » Fri Jan 17, 2020 7:50 pm
The Elf wrote:I've avoided modular so far, but if I could build a 'Roland' System 100, or a 'Moog' 55 for less than the price of a secondhand car I might just break ranks.
Looking at that general design it would be trivially easy to retro-fit one :tongue:
Postby DGL. » Fri Jan 17, 2020 9:29 pm
The Elf wrote:But I want a case with a mains connector!
You can have your mains connector but unfortunately they have decided to use an obsolete mains connector that is only available second hand and even then difficult to find :lol:
DGL.
Postby Sam Spoons » Fri Jan 17, 2020 9:46 pm
Can't see that being a problem TBH, as long as it meets current regs. If they plan to build more than a handful they'll be manufacturing the connectors themselves so loads of new ones easily available.
Postby DGL. » Fri Jan 17, 2020 9:55 pm
Sam Spoons wrote:Can't see that being a problem TBH, as long as it meets current regs. If they plan to build more than a handful they'll be manufacturing the connectors themselves so loads of new ones easily available.
Though try finding one in time for a gig when the one you had is either lost or damaged!, oh and they better make it so a standard connector cannot be retrofitted.
DGL.
Postby Folderol » Fri Jan 17, 2020 10:21 pm
DGL. wrote: oh and they better make it so a standard connector cannot be retrofitted.
Ummm. Why? :?
Postby DGL. » Fri Jan 17, 2020 10:33 pm
Ummm. Why? :?
It was a joke about your hatred of external power bricks :lol: and trying to make that internal PSU as inconvenient as possible, making the mains connection method just as bad as a power brick in terms of replacement if lost/damaged. I suppose fitting a proper C15/16 kettle lead, the even higher temperature C15/16A or the 16A variant (C19/20/23/24) would be just as inconvenient as some bespoke connector.
IEC all the way for me on products, although the miniak had to have a C8 figure of 8 as an C14 would have been too big and I haven't tried bodging the MS-101 yet.
DGL.
Postby Sam Spoons » Fri Jan 17, 2020 10:37 pm
My Miniak has a DC brick, can't remember if it has a fig 8 into that but it certainly doesn't have an internal mains PSU......
WRT the Berry, most kit comes with EU and UK mains leads, it's cheap enough for them to do so and easy enough for you to chop the redundant plug off and fit another UK one so you always have a spare cable.
Postby DGL. » Fri Jan 17, 2020 10:51 pm
Sam Spoons wrote:My Miniak has a DC brick, can't remember if it has a fig 8 into that but it certainly doesn't have an internal mains PSU.......
Well a normal MINIAK does have an external 9V AC brich but mine failed and getting a 9V AC brick was not too cheap, so I got a spare linear DC brick, smashed it open and removed the transformer, this was then carefully fitted inside the case in the one place that had just enough room. Noting that much insulation materials were used so as to make it near impossible for any mains wiring to fail in such a way as to make the metal parts of the case live. I did the same to a Roland RS-5 and SH-201 but mounted their own supplies internal to the case, with the SH-201 PSU being placed so that the C8 inlet was positioned to match up with a rectangular hole made in the rear on teh SH-201's plastic case.
The only piece of semi decent A/V related kit that could never have an internal PSU is my Grans EchoStar HDT-610r freeview+ recorder that I got her a few years ago, primarily as it is so slim they actually had to put a slight bulge in the bottom of the aluminum case for the 2.5" laptop HDD! (inc. feet (measuring from the top of the device below it), it's a hair under 15mm)
DGL.
